need help with 2007 5r110 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 28 (permalink) Old 09-06-2014, 10:53 PM Thread Starter
I have a long delay when putting in to gear forward and reverse!
I also have a issue with it sometimes when you put into gear it will go back to neutral for a couple seconds then go back into gear it is also forward and reverse..... shifts fine once is in gear goes down the road fine ....trying to figure out the best solution either fix this one or buy a new one!!!!
I have a superchips cortex tuner on it but still does it when returned to stock
Any help would be great
Thanks Nick
nicktdracing is offline
post #2 of 28 (permalink) Old 09-07-2014, 01:52 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: need help with 2007 5r110
I think it is a sticking solenoid. How old is the ATF? Replacing the ATF and the external filter will sometimes fix this.
Mark
Mark Kovalsky is offline
post #3 of 28 (permalink) Old 09-07-2014, 04:06 PM Thread Starter
Mark fluid is about 12,000 mile old along with internal and external filter
post #4 of 28 (permalink) Old 09-07-2014, 06:24 PM
What fluid was used?
Mark
post #5 of 28 (permalink) Old 09-07-2014, 10:14 PM Thread Starter
motorcraft from dealership I believe type
F
post #6 of 28 (permalink) Old 09-08-2014, 03:03 PM
That will destroy your transmission. Type F hasn't been used since the late 70's. If you really used Type F, then you need a new transmission.
I also don't think Motorcraft has made a Type F since the late 70's.
Mark
post #7 of 28 (permalink) Old 09-08-2014, 03:58 PM
Administrator
Zmann's Avatar
ahh the NOS type F special fluid swap deal
good question / call Mark
Nick the dealership (if Ford) should know to use Mercon SP or LV only
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 28 (permalink) Old 09-08-2014, 04:44 PM
matthewd11's Avatar
If they did use type F, your trans is done.
If they used the correct fluid, replace the line pressure solenoid (PC-A) as well as solenoid E (low/reverse).
Where are you located?
matthewd11 is offline
post #9 of 28 (permalink) Old 09-09-2014, 12:05 AM Thread Starter
wasn't Type F it was Mercon sp not sure why I thought F
did something new today while pullin a good hill towing about 6k lbs
started shifting up then down a few times till I backed off of it
then later in town driving it chattered a couple times while shifting
then had no more issues with it all the way back 3 hr drive other than slow engagement after shutting off and restarting
IM in Columbus ohio
post #10 of 28 (permalink) Old 09-09-2014, 12:22 AM Thread Starter
priced a trans from ford dealer today for 2731.00
thinking about just replacing it instead of chasing problems with money
then still having to do the enevitble
