Transfer Case Leaking - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 09-05-2014, 04:26 PM Thread Starter
jamisgood's Avatar
Hey guys, I've noticed a steady leak under my truck recently. So I got under there the other day and I noticed that the transfer case was wet right where the two case halves meet. What I'm wondering is how exactly do I pull apart this case? It appears there is just RTV in between the two halves. I've been told once I seperate the sides "things" will come out from inside the transfer case. I've never worked on transmissions nor transfer cases so that makes me a little nervous to dig in.
Thanks
01' F350 Lariat ECLB
Mostly stock, just removed muffler and custom welded bend out the side and AFe Stage II intake. Also got 285's and CB radio.
jamisgood is offline
post #2 of 3 (permalink) Old 09-12-2014, 06:04 PM Thread Starter
jamisgood's Avatar
Re: Transfer Case Leaking
Anybody? Somebody? I'm sure someone knows more about transfer cases than I do....
post #3 of 3 (permalink) Old 09-12-2014, 09:10 PM
I've never seen them leak from between the case like that. Double check to make sure it's not a seal higher up and the fluid is running down and dripping off the lowest point which is the case halves. I've never taken one apart but I have had them leak from the driveshaft seal and the seal for the electronic shift motor.
Lipka101 is offline
