Tranny leaking BAD!!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-26-2009, 12:48 PM Thread Starter
ASTRO's Avatar
My tranny is leaking fluid really bad! I seams to be coming from the high/top and in the front. I have just under 110,000 miles on this truck/tranny. Any ideals would be great!! Just can`t seam to locate it , because when I drive it it leaks bad and when you stop it drips off of areas all over the tranny and crossmember. HELP!!!
MY 2002 f250 4x4 larait crew cab short bed. 12.5" Icon lift w/ OneUpOffroad 5" traction bar block system. Mickey thompso 38X15.50R18 tires on Weld Dune 8 18x10 wheels. Custom pearl silver &purple flame paint, MBRP 4" T-304 SS cool dual exhaust w/ custom made T-304SS flame tips, AFE stage 2intake. Way More!
ASTRO is offline
post #2 of 4 (permalink) Old 07-26-2009, 08:58 PM
matthewd11's Avatar
Re: Tranny leaking BAD!!!!
Is it coming out of the vent tube?? Whats the trans temp??
matthewd11 is offline
post #3 of 4 (permalink) Old 07-26-2009, 10:00 PM Thread Starter
ASTRO's Avatar
My tranny runs about 70- 80 degrees above the outside temp. The hotest I`ve ever seen my tranny temp is 180 degrees. what do I do to fix it? also thanks for your help!!
ASTRO is offline
post #4 of 4 (permalink) Old 07-26-2009, 10:47 PM
Can't you stand under your truck and look at it at eye level, lol. Do you continue to add fluid to the tranny in order to drive it? Try to at least decipher what side of the transmission the leak coming from so we can help further.
For Sale: 2000 F350, black cc sb 4x4
Jngreen is offline
