E4OD Reverse Only - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 07-19-2009, 05:07 PM Thread Starter
Third Member
gtndrty's Avatar
E4OD Reverse Only
My friend has a 95 F-250 4X4 E4OD. The transmission has been rebuilt within the last year.
He was driving the pickup, put it in park and got out, and when he got back in the only gear he had was reverse. I checked the codes and nothing showed up in engine off, engine running, or memory. The range selector shows all the right gears when I run the shifter manually thru them. All the external wiring looks good and it's not leaking any fluid.
Any ideas if it's solenoid, valve body, or something else internal?
Thanks
1995 F-350 CC 4X4, Auto, 3.55's, DP, No Kitty, Straight Pipe, Wildman 4 Position Chip, Gutted EBPV, Modded Turbo Pedestal, Autometer A-Pillar gauges, Tymar Open Element Intake, HPX Hose, Shimmed FPR, SP Diesel EBP Dongle, 466 Blue CPS
gtndrty is offline
post #2 of 2 (permalink) Old 07-20-2009, 11:10 AM
Shaw's Avatar
Re: E4OD Reverse Only
Check this thread out, forward gears, what gives? - Powerstroke Nation
"It's JUSTa 7.3"
His - 01 F-350 Reg cab 4x4 auto
Hers - 00 F-350 Crew long bed 4x4 auto
Kids - 01 EX Limited
Toy - 97 F-350 Reg cab 4X4 5spd
Shaw is offline
