4r100 trans problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 07-19-2009, 12:43 PM Thread Starter
The truck in my sig is having some trans issues. It was rebuilt at 92k local builder with a twin disc converter. At about 100k I noticed a shutter when rolling under idle power. At that time the truck was stock and if I put the petal to the metal it worked great. I took it back to the builder and they said it was the planetary (what ever that is) but would not warranty it as I was over the warranty time. (Losers lost my business for ever!)
It is still doing the shutter thing but now with the chip added it slides into drive and overdrive under 3/4 to full power runs. When it is doing this if I let out of the power it goes right into gear. 1st to second shifts and second to drive are firm and crisp. When driving normal it works flawlessly. I do not drive it hard and it only tows a small boat. I have never seen the trans temp over 155.
Any ideas would be great. Wondering if it might be the chip or maybe it could use a valve body upgrade. The T/C locks up just fine under full power but is a bit harsh.
Thanks in advance for the help.
2001 Crew Cab Lariat F350 4x4 Auto 120k
Mods:
6637
Level kit
Ranch Hand brush guard
Gauges trans, boost, pyro
4" Exhaust
DP Tuner
Rebuilt trans at 92k Local rebuild twin disc
Future mods in order:
Trans cooler
6.0 Intercooler mabey
Stage 1 singles
38r
BACDRAFT is offline
post #2 of 7 (permalink) Old 07-24-2009, 12:18 AM Thread Starter
Re: 4r100 trans problems
-Bump-
Any help would be great.
Thanks
Mods:
6637
Level kit
4" Exhaust
DP Tuner
Trans cooler
Stage 1 singles
38r
BACDRAFT is offline
post #3 of 7 (permalink) Old 07-24-2009, 11:40 AM
Shaw's Avatar
Sounds like its slipping. More power (chip) = more slipping. I would think any reputable transmission shop would do more then just say " your out of warranty " if you only had 8k miles on THERE rebuild! That would make me question what all they did when they rebuilt it. My guess is trany needs gone thru again, sorry.
"It's JUSTa 7.3"
His - 01 F-350 Reg cab 4x4 auto
Hers - 00 F-350 Crew long bed 4x4 auto
Kids - 01 EX Limited
Toy - 97 F-350 Reg cab 4X4 5spd
Shaw is offline
post #4 of 7 (permalink) Old 07-24-2009, 08:07 PM
aklim's Avatar
Try giving BTS a call. He might be able to help you or at least give you some advice what to do. Or he could sell you a new trans that you won't have problems with. 870-422-3673
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #5 of 7 (permalink) Old 07-24-2009, 08:23 PM
Everybody poops <~ see?
dennisr_f350's Avatar
Send a message via MSN to dennisr_f350
Check you fluid level, but more importantly check it for ANY particulate debris in your fluid. Look closely for what would look like pepper in your ATF, or worse would small metal shards. This will indicate what's coming apart inside your transmission. Tranny failures are ALWAYS a chain reaction, until it's big enough to stop you in your tracks.
What type of TC was installed? Was it a FoMoCo part?
2007
F350 SuperDuty
Some air
Some fuel
Some grip
Some guages
The usual suspects.
dennisr_f350 is offline
post #6 of 7 (permalink) Old 07-25-2009, 05:53 PM Thread Starter
Thanks for the replies. I checked the fluid level last week and it was full and did not smell burnt. I will check for the pepper look or metal tonight when I get home. The TC came from a local supplier in Portland, OR but I don’t remember their name. My dream is to get a BTS but the funds are short at this time so I am just trying to milk this one for a bit longer. I will also give BTS a call and see what he says I just hate bugging them when I am not ready to buy. Does Brian mind that sort of thing?
Thanks
Mods:
6637
Level kit
4" Exhaust
DP Tuner
Trans cooler
Stage 1 singles
38r
BACDRAFT is offline
post #7 of 7 (permalink) Old 07-25-2009, 07:59 PM
aklim's Avatar
Thanks
Probably not. He didn't mind my bugging him for stuff. He even talked me thru taking my shifter off while I was doing it.
aklim is offline
