"Lost" forward gears, what gives? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 07-16-2009, 09:29 PM Thread Starter
5ninef250's Avatar
Well, I seem to have a prob with my E4. I have reverse, but my forward gears are quite weak. The truck will move forward but under nearly any acceleration it will chatter then slip badly. The pan is pretty clean..... Any ideas? If I manually select 1st it will hold more, but still slips. The trans is a recent rebuild: Stallion converter, Tugger kit, etc. I am using a PCS controller as well. Any thoughts are appreciated...
1997 F250 4X4, E4OD, 12v, SDX 5x14's & DV's, benched pump, 20*, 66/71/13SS, City Diesel 6OH I/C, D60 RSK, SD Springs
1997 F350 CC 4X4, Hypermax Stage 2's, H2E, BTS pumps, BTS trans, Banks I/C
5ninef250 is offline
post #2 of 12 (permalink) Old 07-17-2009, 12:04 AM
matthewd11's Avatar
Re: "Lost" forward gears, what gives?
Who built it? Sounds internal to me.
matthewd11 is offline
post #3 of 12 (permalink) Old 07-17-2009, 04:37 AM Thread Starter
5ninef250's Avatar
Couple local friends/mechanics and me, I suppose we could have screwed something up, but its worked fine for 6/7 mos. This issue just up and happened, can a failed solenoid pack be to blame?
post #4 of 12 (permalink) Old 07-17-2009, 02:36 PM
Shaw's Avatar
My guess would be if this problem is from the beginning, you might have damaged one of the lip seals while putting it together. Did you do air checks to make sure the lip seals were not damaged? I know I have hurt more then one putting them together. If the trany was working and now isn't maybe a overdrive snap ring came off? Ether way it sounds like the trany needs to come out.
"It's JUSTa 7.3"
His - 01 F-350 Reg cab 4x4 auto
Hers - 00 F-350 Crew long bed 4x4 auto
Kids - 01 EX Limited
Toy - 97 F-350 Reg cab 4X4 5spd
Shaw is offline
post #5 of 12 (permalink) Old 07-17-2009, 06:16 PM Thread Starter
5ninef250's Avatar
Yep, we air checked, and it did work fine....this issue came up all the sudden.
post #6 of 12 (permalink) Old 07-17-2009, 08:20 PM
Shaw's Avatar
Since the issue came up all the sudden, my guess is snap ring or something like that. You put it in gear and it doesn't have enough line pressure to hold because the oil is bleeding thru somewhere. Sounds like it needs to come out and gone thru, sorry. Did you use the snap ring that came with the tugger kit, its better then stock but it comes off too. I would use the one from Sonnax
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: High Performance Transmission :: 36744-01 :: Part Summary
"It's JUSTa 7.3"
Shaw is offline
post #7 of 12 (permalink) Old 07-18-2009, 05:16 AM Thread Starter
5ninef250's Avatar
We used the snap ring from the Tugger kit, I call Brian today and he said its a forward drum issue, probably cracked it. So out it comes!
post #8 of 12 (permalink) Old 07-20-2009, 12:55 AM
Hassler Diesel's Avatar
when i lost all my foreword gears and still had reverse it was the bearing in the back of the tranns. u need to go to a double wall bearing.
Hassler Diesel is offline
post #9 of 12 (permalink) Old 07-20-2009, 11:09 AM
Shaw's Avatar
Who sell's it? or do you mean this http://www.sonnax.com/announcements/36008B.pdf
"It's JUSTa 7.3"
Shaw is offline
post #10 of 12 (permalink) Old 07-20-2009, 11:25 PM
i think thats it but not 100% sure. i was told they put a double bearing in the back of the trans and i had to get the intermediate shaft machined to fit. it cost me $1300 to have someone do it all. the whole trans needs pulled apart. give this guy a call 717 861 7525 ask for ladell
