new tranny wont shift - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-15-2009, 07:51 PM Thread Starter
powerstroke7396's Avatar
i just had my trans rebuilt, heavy duty everything and i went with a sun coast converter. however i didnt put in my torq lock. the trans will shift manually but not on its own. any ideas
powerstroke7396 is offline
post #2 of 6 (permalink) Old 07-15-2009, 08:57 PM
Shaw's Avatar
Re: new tranny wont shift
Ive had this happen and for me I had forgot to put some check balls in the valve body
"It's JUSTa 7.3"
His - 01 F-350 Reg cab 4x4 auto
Hers - 00 F-350 Crew long bed 4x4 auto
Kids - 01 EX Limited
Toy - 97 F-350 Reg cab 4X4 5spd
Shaw is offline
post #3 of 6 (permalink) Old 07-15-2009, 09:05 PM
secondarychaos's Avatar
was it done by a shop or you?
If it was done by a shop, i'd just take it to them if at all possible.
my guess would be
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #4 of 6 (permalink) Old 07-17-2009, 03:35 AM Thread Starter
it was built in a shop,i was told its an electrical problem and that i need a new harness for it..... sound right to you guys?
post #5 of 6 (permalink) Old 07-17-2009, 02:45 PM
Shaw's Avatar
I guess that could cause it but I would think you would have a flashing OD light and a code, but I could be wrong? Does it shift thru ALL the gears including OD or do you not have OD?
"It's JUSTa 7.3"
Shaw is offline
post #6 of 6 (permalink) Old 07-22-2009, 01:11 AM
i had the same problem with mine after i installed the tranny and it was the syliniod pack.would shift manually but not on its own.i would check the plugs to make sure that a pin isnt bent or some how gotton pushed down and not making contact.it will be the plug on the right side of the tranny,take off the heat sheild and you can get to it a little easier.
parttime is offline
