rebuilding e4od - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 07-31-2014, 09:34 PM Thread Starter
rebuilding e4od
Just looking for some input on what I would need to rebuild e4od. I have 97 f250 powerstroke 350 hp use it for snow plowing and tow 5 ton trailer quite often. Would like to know what parts I would need. Valve body or triple disk converter.
mwbuilds is offline
post #2 of 8 (permalink) Old 07-31-2014, 10:01 PM
D66stroke
D66stroke's Avatar
Re: rebuilding e4od
When I had mine done, my builder put in the updated 6 pinion steel planetaries from a 4r100, double disk billet converter, and shift kit in the valve body and pump. Make sure to flush the cooler lines and replace the stock cooler with a multirow cooler (6.0 cooler). Mine was making around same power as yours and held up fine after rebuild
97 F-250, 300/100's, e-fuel, Gearhead tunes, Stokers Unlimited stage 3 trans and T4 mount, s366, ARP studs, Comp 910's, Smith Bros PR's
09 Cadillac CTS-V, long tubes/Xpipe, Jeremy Formato tuned, ID850's, 2.38 upper pulley, NorCal icebox, Hennessy heat exchanger
D66stroke is offline
post #3 of 8 (permalink) Old 08-01-2014, 01:18 AM Thread Starter
Re: rebuilding e4od
D66stroke who built your trans I'm in md
mwbuilds is offline
post #4 of 8 (permalink) Old 08-10-2014, 12:45 PM Thread Starter
Re: rebuilding e4od
Where would be the best place place to get rebuild kit from.
mwbuilds is offline
post #5 of 8 (permalink) Old 08-10-2014, 01:28 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: rebuilding e4od
I've purchased many rebuild kits from www.transtar1.com.
Mark
Mark Kovalsky is offline
post #6 of 8 (permalink) Old 08-10-2014, 02:36 PM
m j
m j's Avatar
Re: rebuilding e4od
I recall a lot of the updates for a 4r100 is backdating to 1997 e4od parts
I was researching what I need to do to upgrade a 4r100 and it leads to e4od parts :)
I found this list on google seach here Ford Transmission Forum: E4OD Updates
1997 vintage:
This transmission should already include and meet Ford's own 1997 upgrade specifications":
6 Pinion Forward Steel Planetary Carrier;
4 Pinion Overdrive Steel Planetary Carrier;
Shortened Input Shaft (has grove mark on outter end);
Revised Center Support Shaft(stub removed);
Center Support Hub with R-16 Roller Bearing (Instead of Bushing);
Forward hub/planetary thrust Bearing (Instead of steel washer);
Cup Plug in output shaft to control oil flow; and
Center Support Hub silcone lined gasket (better seal)
The only thing that I see that would be an update would be the 1998 E4OD/4R100 pump.
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
post #7 of 8 (permalink) Old 08-13-2014, 12:40 AM
D66stroke
D66stroke's Avatar
Re: rebuilding e4od
A family friend that is retired from doing transmissions all his life, and now only does race transmissions for drag cars. I'd give you his info but I had a bad experience with the last guy I helped out. I hooked my friend up with him, my guy builds his trans and tried getting ahold of my friend for a month after it was done and basically got screwed over with the whole deal. So he told me he's not doing anymore business with people I send to him
post #8 of 8 (permalink) Old 08-16-2014, 12:33 AM Thread Starter
Re: rebuilding e4od
Ok. I understand about that. Just thought I ask.
mwbuilds is offline
