A few trans questions.... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 07-13-2009, 10:34 PM Thread Starter
theSLEEPER's Avatar
What are symptoms of a weak pump? My trans shifts crisp and smooth, and everything seems fine, but on lock-up, I still feel a slight "bounce" at times (mostly low rpm locked, sometimes on lock-up). Could this be a U-joint issue? I'd like to get it on a scanner, could that tell me if I had low pressure?
And when I shut the truck off, I get a sqeek/rattle type sound. Should I have used locktite on the converter bolts?
theSLEEPER is offline
post #2 of 12 (permalink) Old 07-13-2009, 10:59 PM
Re: A few trans questions....
the bounce is probably leaf springs. as for u-joints, i oculd feel mine by going into over drive, letting off the throttle then getting back in it again and hearing a thud.
PMRCM#1
slowleak is offline
post #3 of 12 (permalink) Old 07-13-2009, 11:53 PM Thread Starter
theSLEEPER's Avatar
Good call Doug. But what about the low RPM TC locked condition?
Do you know if there's a way to simulate trac bars with straps? Maybe strap the axle to the reciever??
post #4 of 12 (permalink) Old 07-14-2009, 12:02 AM
Everybody poops <~ see?
dennisr_f350's Avatar
Send a message via MSN to dennisr_f350
Best bet to see your line pressure/pump pressure is a scanner, I prefer the OTC scan tools, if you have a choice.
And the 'strap bars' would likely be better going from the axle to a forward position, but where..... (could be wrong, it's happened before)
2007
F350 SuperDuty
Some air
Some fuel
Some grip
Some guages
The usual suspects.
dennisr_f350 is offline
post #5 of 12 (permalink) Old 07-14-2009, 12:05 AM
Can ae do this???
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
rpm-inc is offline
post #6 of 12 (permalink) Old 07-14-2009, 12:05 AM
Oh! one more thing, double check you fluid level, as the TC is among the first to suffer from low fluid (causing lack of constant pressure).
2007
F350 SuperDuty
Some air
Some fuel
Some grip
Some guages
The usual suspects.
post #7 of 12 (permalink) Old 07-14-2009, 12:07 AM
Of course, any diag setup should be able show operating pressures. Best is to do it while running (KOER), to see if if fits inside the factory perameters.
2007
F350 SuperDuty
Some air
Some fuel
Some grip
Some guages
The usual suspects.
post #8 of 12 (permalink) Old 07-14-2009, 12:20 AM Thread Starter
theSLEEPER's Avatar
Do you know what kind of pressures I should be looking for? I'm gonna check it out ASAP...
Is there a test port for me to use a mechanical gauge?
post #9 of 12 (permalink) Old 07-14-2009, 12:28 AM
AllYourBaseAreBelongToUs
imelmo's Avatar
You can bring it by and hook my AE to it if it shows that.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #10 of 12 (permalink) Old 07-14-2009, 01:49 AM
There is always a mechanical check plug, but I don't know where it is on your 4R100. TCC line pressure should be in the neighbourhood of 95 psi at lock-up, near triple that in reverse. Again, I could be wrong.
2007
F350 SuperDuty
Some air
Some fuel
Some grip
Some guages
The usual suspects.
