Clutch - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 07-12-2009, 03:46 PM Thread Starter
Clutch
I noticed my clutch slip the other night so its time for a new one and was looking to get some recommendations on what to get. I dont plan to make alot of HP but I do tow heavy. This is in my '03 4x4 250. Thanks folks.
Lee
"Insane, am I the only mofo with a brain?
I'm hearing voices but all they do is complain!"
King0581 is offline
post #2 of 10 (permalink) Old 07-12-2009, 04:58 PM
dpwilson's Avatar
Re: Clutch
I really like my Valair. I know Southbend is popular too but I like to be different. Either way I don't think you would be dissapointed. While you're at it you might want to take a look at your hydraulic assembly. They seem to be the weak point in the ZF6.
BTW, try to have a plan on what kind of power you want to make and get the clutch to support the future mods now.
Derek
Early 99 6spd: Valair Kevlar/ceramic clutch, DI intercooler, 6637 filter, DIY exhaust brake, Isspro gauges, DP tuner NS, S, 40T, 60T, 80E 120R, 5" exhaust, 2.5 in leveling kit with 285/75/16.
dpwilson is offline
post #3 of 10 (permalink) Old 07-12-2009, 05:00 PM
JHill's Avatar
Re: Clutch
there are several good ones out there,
SBC get's my vote-http://www.southbendclutch.com/ford_catalog.html
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #4 of 10 (permalink) Old 07-12-2009, 06:05 PM Thread Starter
Re: Clutch
Thanks. So I was checking out the South bend clutches an see that they have the HD set that is good to 400hp and the con O thats good to 350hp. At my best guess I might be making 330hp tops' and thats being generous. So I wonder which one to go with? It says the HD is like a semi truck's clutch, so I wonder if it would be harder shifting? I guess I will have to give them a call tomorrow.
Lee
King0581 is offline
post #5 of 10 (permalink) Old 07-12-2009, 06:38 PM
dpwilson's Avatar
Re: Clutch
If you're going to do the clutch I would suggest min. of the con ofe. If you get addicted to modding your truck, you're gonna sail right past that con o comfort zone. I'm sure there isn't much of a cost difference between the two.
Derek
dpwilson is offline
post #6 of 10 (permalink) Old 07-12-2009, 08:39 PM
Senior Veteran Member
Centxdiesel's Avatar
Garage
Re: Clutch
I love my Valair Ceramic-Kevlar. They are great people to deal with also. Just my .02.
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #7 of 10 (permalink) Old 07-12-2009, 09:03 PM Thread Starter
Re: Clutch
I have no problem with going with a bigger clutch. I dont plan to go any further on these PMR's and they are going to be in there for a good while. I had heard that you could go overkill on the clutch by getting one for more HP and not having it.
Lee
King0581 is offline
post #8 of 10 (permalink) Old 07-13-2009, 09:37 PM Thread Starter
Re: Clutch
Well I must be loosing my dang mind! I went back to the same hill and this time I took my boat and did a hard run and it didnt slip at all. I had had a couple drinks but dang, I would have swore it was slipping. Ha Ha! I'm going to see how it does for a while before I drop the money on the clutch. Thanks guys.
Lee
King0581 is offline
post #9 of 10 (permalink) Old 07-13-2009, 10:40 PM
familytradition3's Avatar
Re: Clutch
I have a SBC 3600 DD and i love my clutch. I pull a goose neck that wieghs around 6000 lbs with a pull truck that wieghs 6200, it is smooth on apply doesn't jerk and doesn't shift hard. the guys at sbc recomends the dd if u pull a trailor very often. I know a few guys with the single disks and they do not hold up very well unless u go with a big pressure plate pressure which that affects the shifting and driveablity.
2000 F-350 srw, ex-cab, lwb
TS 6 posi-chip, ATS compressor housing, AFE stage 2 intake, DD SBC, boost annihilator, 3 1/2 down pipe, 4 inch exh, BD waste gate
1975 F-150 4wd 6200 super stock pull truck
built 462 ci motor with eliminator block, billet crank and rods, scj heads
familytradition3 is offline
post #10 of 10 (permalink) Old 07-14-2009, 01:19 AM Thread Starter
Re: Clutch
Thanks for the input. I was going to call them and see what they recommended but like I said, I couldnt make it slip again.
Lee
King0581 is offline
