Lost 6th gear? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 07-11-2009, 10:00 PM Thread Starter
Lost 6th gear?
Posting for a friend who has a 99 F350. I have not had a chance to look at it, but he states that he no longer has 6th gear (fifth on the shifter knob, or overdrive gear). It will feel like it goes into gear with the lever but there is nothing there when you engage the clutch. He claims there are no uncommon noises and he has every any gear but the big one. He can get it to start grinding if he tries to force the shifter farther than normal towards the dash with the clutch to the floor, other than that, there is nothing.
I know the Dodge guys have a problem with a nut backing off and they loose fifth gear. Can it happen to the zf6 tranny too? We will get it figured out, I just want to look for a possible fix before I have to drop that tranny..... again. He has been through a few clutches and I'm tired of working on that truck. The last time was about a year ago and he paid a shop to install a Southbend Clutch. He has probably only put 3-6k on the fresh clutch so I guess it could be something they didn't get put back right.
Any ideas, comments?
For Sale: 2000 F350, black cc sb 4x4
Jngreen is offline
post #2 of 20 (permalink) Old 07-11-2009, 10:16 PM
DD Assisted
DieselRangerKid's Avatar
Re: Lost 6th gear?
Please post your results. I started a thread similar to this one and got 1 response suggesting the syncros. So good luck.
2002 Ford F-250, 7.3, 6spd.
1984 Ford Ranger Diesel - Top Secret
2007 Mazda 6
1952 GMC w/ Ford powertrain, 390, Top Loader 4spd.
2006 Honda TRX450r - Some stuff
2003 Suzuki Eiger
8 John Deere's from 1953 to 1960
Give'r the Onions
DieselRangerKid is offline
post #3 of 20 (permalink) Old 07-11-2009, 10:36 PM Thread Starter
Re: Lost 6th gear?
To me it sounds like something came loose and isn't moving correctly. I hope it is an external problem and not internal.
Jngreen is offline
post #4 of 20 (permalink) Old 07-11-2009, 10:39 PM Thread Starter
Re: Lost 6th gear?
Does the floorboard come out on an early 99 like they do on an older Ford? I know I would have to remove the seat and carpet but to me it would be worth a shot if there was access from inside the cab. I can't remember crap anymore, I've had that tranny out a few times and never thought about looking at the floorboard from the bottom side to see if its removable.
Jngreen is offline
post #5 of 20 (permalink) Old 07-11-2009, 10:50 PM
Crazy Redneck
UNCOOL's Avatar
Re: Lost 6th gear?
Was it ever hard to go into gear in the last 3 to 6k after the clutch was put in?
Did he feel something pop and lost it all of the sudden?
Sounds like a broken or bent shift fork. I don't remember if that is one of the long or short shift forks.
When/if you pull the tranny, just stand it up on the bell housing, remove the BIG nut on the passenger side, (it is a detent for the shift rails, it is also locktited, so it is a bit of a pain) then unbolt all of the casing bolts, and seperate the rear of the case from the front. There is nothing holding the guts too the rear of the case, it will lift off fairly easy when you get the sealant to let go. Then you will be able to look and see if one of the forks is bent or broken.
The floorboard does not unbolt like the older trucks.
Good luck.
Let me know if you need anything else.
Marc
Marc
2000 F350 CC dually auto
Little air, fuel and oil and a BTS.
533/1050 5-8-10
#32
UNCOOL is offline
post #6 of 20 (permalink) Old 07-11-2009, 11:07 PM Thread Starter
Re: Lost 6th gear?
Thank you Marc.
You just told me what I didn't want to know. As far as I know there was no pop or bang or clank when it let go. Just no more big gear. Kurt did say something about taking the shifter out and looking around and the mechanic put something back together wrong. Must not have been a big deal though cause it has been working till now. I wouldn't know, he only calls me when it its really busted.
So is this something that can be easily repaired or should I start looking for a replacement tranny?
Jngreen is offline
post #7 of 20 (permalink) Old 07-12-2009, 01:21 AM
Crazy Redneck
UNCOOL's Avatar
Re: Lost 6th gear?
When I get home tonight, I will look thru my stuff and figure out what one is the correct one, and send you a link to the stuff I have.
I have had mine apart and hence the reason for the auto swap I am doing.
Marc
533/1050 5-8-10
#32
UNCOOL is offline
post #8 of 20 (permalink) Old 07-12-2009, 04:10 AM
Crazy Redneck
UNCOOL's Avatar
Re: Lost 6th gear?
Try this. It gives a semi detailed view of the interals.
#19 in the drawing is the 5-6 shift fork, so it is likely that it could have broke.
ZF6 Speed Manual Transmissions Part, Rebuild Overhaul Kits Ford Truck - Drivetrain.com
Good luck.
Marc
Marc
533/1050 5-8-10
#32
UNCOOL is offline
post #9 of 20 (permalink) Old 07-12-2009, 05:08 AM Thread Starter
Re: Lost 6th gear?
Good luck.
Marc
Excellent info, thanks again Marc. Looks like a good time
If I run into any problems, I'll hit you up.
Jngreen is offline
post #10 of 20 (permalink) Old 07-12-2009, 05:20 AM
Crazy Redneck
UNCOOL's Avatar
Re: Lost 6th gear?
805-712-7252 cell, any time.
I have the tool kit for the ZF if you need to go farther.
Marc
533/1050 5-8-10
#32
UNCOOL is offline
