Transmission Broke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 11-28-2007, 12:43 AM Thread Starter
10.61 @ 128 MPH
Powersmoker's Avatar
Send a message via AIM to Powersmoker
Transmission Broke
yea i broke the dam transmission in the ol superduty. stock besides a shift kit to my knolledge. 223k miles. bought it at 130k.
just got done puting the fuel system in , dual hpops and tonight just finally got a insanity file / tune for the truck. my estimate around 500hp. got on it a couple times and truck pulled rear hard.....shifted decent.......then on my way home on bell island rd i eased into the throttle ( 3rd gear tc locked) and right when the turbo started to light....i heard a big snap - bang under the truck . the truck rolled for about a half a mile.....wouldnt move in any gear. i think i broke something inside possible shaft or tc???? no evidence of trans getting worse before it quit. trans code po743. i think thats the same code that always come up if i leave the tc lock up at low speeds. o well it only money....time to get a bts
2000 F-250 Regular Cab
1069 RWHP 1768 Torque
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Murff Racing Twisted Diesel
Empire Diesel DieselSite
Swamps Diesel
Powersmoker is offline
post #2 of 31 (permalink) Old 11-28-2007, 12:45 AM
Re: Transmission Broke
500 hp will do that to a stcok tranny
PMRCM#1
slowleak is offline
post #3 of 31 (permalink) Old 11-28-2007, 12:49 AM
DILLIGAFF
Send a message via AIM to Redfish
Sounds to me like it could be the flywheel, see if this sounds familiar: https://powerstrokenation.com/forums/...ead.php?t=2358
2006 F-250 CC King Ranch, Harley Headlights w/ 55w HIDs
ARP studs, MBRP 4" exhaust and AM Colbalts By:
, AFE stg. 2 Pro Guard 7 from XDP, SCT from innovative!
14.09 @ 94 1.85 60'
Redfish is offline
post #4 of 31 (permalink) Old 11-28-2007, 01:00 AM Thread Starter
10.61 @ 128 MPH
i dont think it is the fly wheel / flex plate....truck idles normal....no weird noises, starts fine........just no movement in any gears. the crazy thing is the fluid looks and smell ok to me.
i was lucky to get this amount of miles out of it...i have had a tuner on it since 140k. 180cc injectors at 190k then at 219k miles i upgraded to bb turbo and 230cc injectors...so shes definitlty due for a good trans
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Swamps Diesel
post #5 of 31 (permalink) Old 11-28-2007, 01:28 AM
OBS junkie
Cat_Rebel's Avatar
Probley snapped your output shaft, I've seen it before.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #6 of 31 (permalink) Old 11-28-2007, 01:35 AM
member
Go BTS and dont look back.Also try cales tunes,they are very smooth and made better HP on the dyno.
F350cc4x4sb,BTS Trans, H2E Turbo,Tapor core IC,530mm injectors,Head studs,DI regulated return and total fuel system.
Astnpwr is offline
post #7 of 31 (permalink) Old 11-28-2007, 01:50 AM
I don't see him snapping the output shaft in third gear.
Also if you can use a wrench build it yourself.
BlindViper is offline
post #8 of 31 (permalink) Old 11-28-2007, 01:53 AM
DILLIGAFF
I say at least take the inspection plate off and look at the TC/flywheel.
14.09 @ 94 1.85 60'
Redfish is offline
post #9 of 31 (permalink) Old 11-28-2007, 03:52 AM
X Racer
Racer X's Avatar
truck pulled rear hard.....shifted decent.......then on my way home on bell island rd i eased into the throttle ( 3rd gear tc locked) and right when the turbo started to light....i heard a big snap - bang under the truck . the truck rolled for about a half a mile.....wouldnt move in any gear. no evidence of trans getting worse before it quit. trans code po743.
0743 is a TC code. Is your truck trying to move but lugging? Or does the engine rev up freely with no load?
A loud snap usually is not good either way.
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
post #10 of 31 (permalink) Old 12-03-2007, 10:39 PM Thread Starter
10.61 @ 128 MPH
the truck doesnt even try to move at all........the engine revs freely. no noises or anything. i can shift it from park to any other gear with throotle and nothing happens....it runs like its in nuetral all the time.
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Swamps Diesel
