O/D light flashing-codes pulled - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 07-14-2014, 06:41 PM Thread Starter
mbg75's Avatar
2002 f250 4x4 7.3
O/D light flashing, flashing starts as soon as it's put in gear.
Pulled codes
Po705
Po708
P1832
Trans range sensor codes.
Trans was rebuilt at 120k. Truck is currently at 225k.
Any help appreciated!
2002 F-250 ccsb, 7.3, Auto, 4x4, BDP Tunes, Stealth Drop In, 4" MBRP, 6637, Van turbo WW ATS, Frantz Bypass,Drilled & Slotted Rotors
mbg75 is offline
post #2 of 9 (permalink) Old 07-14-2014, 06:52 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: O/D light flashing-codes pulled
My guess is that you have a bad transmission range sensor. It's the sensor located on the driver's side of the transmission, where the shift cable attaches. It is also possible that the sensor is fine and some of the wires to the sensor are damaged.
Mark
Mark Kovalsky is offline
post #3 of 9 (permalink) Old 07-14-2014, 07:39 PM
SledDogg's Avatar
About $80 from Dealership. But you have to have a scanner to install it. Gotta "clock" it to read correct gear.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #4 of 9 (permalink) Old 07-14-2014, 08:11 PM Thread Starter
mbg75's Avatar
Just looked under the truck. I see that someone ran 2 wires from the sensor pigtail up the the ECM bulkhead on the firewall. The connections are soldered. Previous problem I guess.
I cleaned and di-electric greased the 3 plugs up on fender well and the pigtail by trans.
Is it worth pulling the harness to inspect it? Or just find a replacement?
mbg75 is offline
post #5 of 9 (permalink) Old 07-15-2014, 01:19 AM Thread Starter
mbg75's Avatar
Cleaned connectors. Changed sensor. So far light is off.
mbg75 is offline
post #6 of 9 (permalink) Old 07-15-2014, 01:43 AM
No, you do not need a scanner to install a range sensor.
The trans has to be in neutral to install it. There is a mark on the inner rotating part that aligns with a mark on the TRS case when in neutral. If you align these it will be perfectly "clocked."
Mark
post #7 of 9 (permalink) Old 07-15-2014, 02:26 AM Thread Starter
mbg75's Avatar
Thank you for the help. I'll post back on the results.
mbg75 is offline
post #8 of 9 (permalink) Old 07-17-2014, 12:38 AM
SledDogg's Avatar
Thanks Mark....two weeks to late. D'oh
SledDogg is offline
post #9 of 9 (permalink) Old 07-19-2014, 03:02 PM Thread Starter
mbg75's Avatar
So far, so good. Light hasn't come back on.
mbg75 is offline
