dies in reverse - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-12-2014, 08:53 AM Thread Starter
1TONPSD's Avatar
dies in reverse
I have an early 99 that dies in reverse, it has a bully dog shift kit an ATS deep pan and a PI torque converter. If I don't have my chip in high idle when I shift into reverse the truck will lug and die. Any help would be appreciated.
99 F350 reg cab
238/80 inj.
diesel site CPRx fuel system
High pressure crossover
TN ball bearing charger
ARP studs
AFE stage 2 intake
DP tuner F5
4" down pipe
5" miter cut stacks
PI convertor,bullydog shift kit, deep pan
modded 17* by terminator
1TONPSD is offline
post #2 of 4 (permalink) Old 07-13-2014, 01:02 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: dies in reverse
Low trans fluid or a loose/missing internal filter will cause this. So can worn internal seals or a worn pump.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #3 of 4 (permalink) Old 07-20-2014, 07:20 PM
444_4x4's Avatar
Re: dies in reverse
^^^+1
2000 F350 SD 4X4 CC LB Lariat
, GTP38R, 4"DPPI Turbo back, PHP Hydra, J/S IDM, aFe Magnum, A-Pillar Autolites Trans/EGT/Boost, APCM(AIC), Boost Bleed Off, 4" Lift, W/315's, Warn Hubs, Dual alt's., Racor 4500 CCV, ARG SuperPump and Gear
444_4x4 is offline
post #4 of 4 (permalink) Old 07-25-2014, 03:10 AM Thread Starter
1TONPSD's Avatar
Re: dies in reverse
Thanks so much guys
99 F350 reg cab
238/80 inj.
ARP studs
AFE stage 2 intake
DP tuner F5
4" down pipe
5" miter cut stacks
1TONPSD is offline
