Trans Problem Need As Much Help As I Can Get!!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-08-2009, 03:31 PM Thread Starter
I have a 2000 F250 with the 7.3L no aftermarket mods and this just started happening... When I put the trans in any gear the truck stalls out completelly dead truck restarts every time, when i do get moving in any gear above 2nd the truck runs and drives just fine no check engine light and the overdrive light is not flashing, help!!!
dieself250 is offline
post #2 of 5 (permalink) Old 07-08-2009, 03:41 PM
theSLEEPER's Avatar
Re: Trans Problem Need As Much Help As I Can Get!!!!
Mine did that the other day when I was first putting fluid in the new TC. Are your fluid levels right? Maybe something is wrong with the TCC?
theSLEEPER is offline
post #3 of 5 (permalink) Old 07-08-2009, 03:49 PM Thread Starter
My fluid levels are fine i have checked it like 100 times and the fluid is a good color
post #4 of 5 (permalink) Old 07-08-2009, 05:30 PM
ELKHUNTER's Avatar
Sounds like your converter clutch is not unlocking, need to check line pressure and pump flow volume first.
Josh
2000 F350 205,000
STAGE II SPLITS 100%
STEALTH SRP1
TYRANT TUNES
38R TURBO
BTS VALVE BODY
WALBRO 392
SCANGAUGE
ISSPRO
MORE STUFF
ELKHUNTER is offline
post #5 of 5 (permalink) Old 07-08-2009, 07:48 PM
Bigfoot is an OBS
cowboy_dan's Avatar
Go ARMY!
cowboy_dan is offline
