Front Seal Leak "Repaired" but Still Leaking - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-09-2014, 04:33 PM Thread Starter
Arrow Front Seal Leak "Repaired" but Still Leaking
I had the dealership repair the classic symptoms of a front seal leak on the transmission.
But, after one long drive in 98° weather, the leak was back.
Is there any other seals that should have been replaced, other than what is shown on my invoice ?
Thanks for any help.
bill4d is offline
post #2 of 4 (permalink) Old 07-09-2014, 09:04 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Front Seal Leak "Repaired" but Still Leaking
Your invoice shows that they didn't touch the transmission. They replaced the front seal on the transfer case, not the transmission.
Mark
Mark Kovalsky is offline
post #3 of 4 (permalink) Old 07-29-2014, 05:00 AM
tbolt's Avatar
I had the same issue. It wasn't the seal but the pump cover was leaking. But from what Marks said they worked on the wrong end. WOW.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #4 of 4 (permalink) Old 07-29-2014, 08:58 PM
It isn't what I said, it is what is printed on the receipt.
Mark
