New one on me - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-08-2014, 05:40 PM Thread Starter
New one on me
last week I got home with heavy loaded trailer, pulled in my driveway and truck would not move forward or reverse. Leaking trans fluid every where.
Next day put a gallon of trans fluid and have been driving it for a almost a week and trans has not leaked a single drop. This is in my 2002 super duty with auto.
kool merc is offline
post #2 of 6 (permalink) Old 07-08-2014, 07:53 PM
Roenicke95stroker's Avatar
Re: New one on me
I believe Your trans has what's called and overflow valve, it dumps fluid when your trans get way to hot, above 230*. Any chance you have gauges/tuner? That could tell us what the temp was when this happend?
Roenicke95stroker is offline
post #3 of 6 (permalink) Old 07-08-2014, 07:55 PM
Re: New one on me
Too much pressure- causes it to dump out of the overflow/pressure release. It's a little slit on the front bottom of the case. You prolly dumped enough that your torque converter didn't register
post #4 of 6 (permalink) Old 07-08-2014, 08:02 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: New one on me
No, that's wrong. There is no overflow, nor is there a pressure release.
The problem is that in low speed, high load reversing the torque converter gets REALLY hot. This causes the torque converter hub seal to get too hot and it softens. Then it leaks. Sometimes a lot. Once it cools it seals up again.
The seal can do several cycles of this before it fails. There is an aftermarket seal made from Viton that is MUCH better than the stock seal.
Mark
Mark Kovalsky is offline
post #5 of 6 (permalink) Old 07-08-2014, 08:07 PM
Re: New one on me
That's wierd I guess my transmission techs need to go back to school, I was told when I went hunting this winter and had to push through 2 feet of snow overheating my tranny them dumping oil out of a slit in the front bottom of the transmission that it was my transmission blowing the oil out due to over pressure. My bad sorry for the ignorant reply, thought my tranny guy knew what he was talking about. Won't be giving him anymore business
post #6 of 6 (permalink) Old 07-08-2014, 08:59 PM
Re: New one on me
Yes, they need to go back to school. They don't know what they are talking about.
Mark
