02 shift to OD - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-07-2009, 12:12 AM Thread Starter
RDRCM
CooterBrown's Avatar
02 shift to OD
Dad's truck.
He says it's been randomly not shifting to OD over the last few weeks. It wasn't wanting to shift into OD at all today so I had him pull the chip. It has the same symptoms, not good.
He says if he is doing 60 @2500, shifts to neutral, revs the motor a little off idle, puts back in drive, it will shift into OD. The tranny does not slip, has no abnormal heat, and doesn't even mind being lugged in OD once it's there.
It will shift to OD at 65 mph.
Solenoid pack?
VSS?
CooterBrown is offline
post #2 of 5 (permalink) Old 07-08-2009, 06:47 PM
They call me Nobody
Dantheman's Avatar
Re: 02 shift to OD
Originally Posted by budro View Post
Solenoid pack?
That is what happened to my factory trans.
02 F250 Lariat Dark Shadow Gray, 343,000 miles on the clock, 4in. lift, 4in. exhaust system w/5"stack, BTS Trans, DIY regulated return.
"A fanatic is someone who cant change their mind and wont change the subject" Winston Churchill
Dantheman is offline
post #3 of 5 (permalink) Old 07-09-2009, 12:12 AM Thread Starter
RDRCM
Re: 02 shift to OD
Started flashing OD light last night. P0783
Again, there is no slipping at all, just not shifting to OD when it should.
post #4 of 5 (permalink) Old 07-09-2009, 12:22 AM
<--Spy Vs. Spy
theSLEEPER's Avatar
Re: 02 shift to OD
Almost the same thing happened to my factory trans... it would shift to 4th but not lock...
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #5 of 5 (permalink) Old 07-09-2009, 12:30 AM Thread Starter
RDRCM
Re: 02 shift to OD
That's not almost the same thing at all. The truck does not try to shift period, until 65 mph, some of the time, meaning randomly. Other times it shifts like it should at the normal mph. I had him clear codes, pull battery cables, touch + & - together to reset things. Truck has driven flawlessly for 20+ miles at this point. I'm sure it will be back, just tells me it's not mechanical.
