4r100 shifting issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 07-01-2014, 02:16 PM Thread Starter
diesel_84's Avatar
I bought my 01 F350 about 2 years ago in the summer and noticed when it got cold and I was running up a hill, it'd bang into gear... enough to jerk me in my seat. My brother said it was just bc it was cold and I didn't give it enough time to warm up - so next time I let it warm up longer. It didnít do it for awhile and I try to be cognizant of how I drive it up hills for this reason. Recently going up hills, itíll shift 2nd to 3rd to 4th in a matter of seconds. And RPMs drop drastically but it wonít stop moving so I keep trucking on. Also recently when I shift into reverse or drive I hear a clink Ė kinda of like a manual transmission would sometimes do. I donít have any codes or any other issues with it but am curious as to what my issue is or anyone else has faced this problem. I donít really have $4k to buy a BTS or JW trans so thatís out. New Valve body and shift kit help? New Torque Converter? Any words of wisdom or help would be greatly appreciative.
2001 F350 CC LB. 6637 intake, 5" Diamond Eye, gauges, Beans Tunes - stock, tow, economy, daily, performance, high idle; 4" lift, 315/7516 Toyo AT2 & XD Addict.
ΜΟΛΩΝ ΛΑΒΕ
diesel_84 is offline
post #2 of 17 (permalink) Old 07-01-2014, 02:29 PM
mech 1
Re: 4r100 shifting issue
mine done that and now no second gear good luck but the hard shift did the light on the shifter come on when it did it.
7.3mud is offline
post #3 of 17 (permalink) Old 07-01-2014, 03:43 PM Thread Starter
diesel_84's Avatar
nope, there was no light or anything. I checked codes numerous times just incase the bulb was burnt out, nothing.
ΜΟΛΩΝ ΛΑΒΕ
post #4 of 17 (permalink) Old 07-01-2014, 03:44 PM Thread Starter
diesel_84's Avatar
i'll probably just have my brothers friend rebuild it and get a TC, new valve body, and shift kit and call it a day. im never gonna hit crazy HP numbers
ΜΟΛΩΝ ΛΑΒΕ
post #5 of 17 (permalink) Old 07-01-2014, 03:48 PM
mech 1
well mine did the quick shifting from first to second then third like really quick for a week now no second gear pulling it friday the clank noise is slack either in the transfercase or the rear end
7.3mud is offline
post #6 of 17 (permalink) Old 07-01-2014, 04:18 PM Thread Starter
diesel_84's Avatar
the clank bad? like should I be worried about it?
ΜΟΛΩΝ ΛΑΒΕ
post #7 of 17 (permalink) Old 07-01-2014, 04:47 PM
the stryker god
Maybe its the dreaded mechanical diode
bruce51d is offline
post #8 of 17 (permalink) Old 07-01-2014, 05:15 PM Thread Starter
diesel_84's Avatar
I'm guessing this is tough to fix since its dreaded? Or is it an easy fix. I really just want to get a John Woods trans but I believe my wife would just bury me in the back yard
ΜΟΛΩΝ ΛΑΒΕ
post #9 of 17 (permalink) Old 07-01-2014, 08:41 PM
mech 1
well the clank could just be slack in the rear end or in the t case check the rear end if its got more than .010 slack thats we its coming from if its not vibrating and making noise and not over say .025 back lash wouldnt worry alot the clank is more than likely not in the tranny
7.3mud is offline
post #10 of 17 (permalink) Old 07-03-2014, 02:30 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
The clank is most likely either a dry slip yoke or a bad ujoint.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
