Eo4d funny shifting that's not so funny - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 06-23-2014, 02:51 AM Thread Starter
Mattstunt929's Avatar
Hello everyone!
Recently purchased my first 7.3!! The truck had been sitting for 1.5-2 years.
I got it running checked the tranny and it was 7qts low. Took it out and drove it. Shifting 1st to 2nd seems correct but from 2nd to 3rd the truck has to be way high in the rpms to shift then as soon as it shifts to third it almost immediately shifts to 4th.
Some times I have kinda feather the throttle to get it to shift when shifting 2-3 and 3-od.
Supposedly the tranny was replaced and then had a solenoid replaced before being parked for two years.
Any suggestions?
Mattstunt929 is offline
post #2 of 24 (permalink) Old 06-23-2014, 12:34 PM
Luddite in Charge
Mr_Andy's Avatar
Re: Eo4d funny shifting that's not so funny
Filter? 7 quarts low indicates a sizable leak.
Mr_Andy is offline
post #3 of 24 (permalink) Old 06-23-2014, 02:34 PM Thread Starter
Y'all think change the filter? The leak is coming from the pan.
post #4 of 24 (permalink) Old 06-24-2014, 02:06 AM Thread Starter
Any other suggestions anybody??
post #5 of 24 (permalink) Old 06-24-2014, 02:45 AM
old Smokey's Avatar
Have you tried to shift it manually? You can see if it shifts right on time and if so then you more then likely have a bad sensor or electrical problems.
96 with 320,000, Idm mod,
Tc mod, van turbo, 200/30 rosewood,
T 500 hpop, Dy 3" down pipe,
glowshift gauges, D60kp swap, custom track arms,
steering wheel swap, 6637 mod, Hydra chip, WW2,
calf fuel spring and BB mod
6.0 fan, cooler,
Pmf 2.25 rsk sd springs
78 f-150 turbo big block
old Smokey is offline
post #6 of 24 (permalink) Old 06-24-2014, 03:12 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Now that you've driven it for a while check the fluid level again.
The best place to start is to get the codes read. Cheap scanners like the auto parts stores use WILL NOT read these codes.
Mark
Mark Kovalsky is offline
post #7 of 24 (permalink) Old 06-25-2014, 12:29 AM Thread Starter
What rpms does a stock f350 eo4d shift at?
post #8 of 24 (permalink) Old 06-25-2014, 01:07 AM
Roenicke95stroker's Avatar
I had this same problem for a while, my tranny ended up taking #### on me. Not saying that is what it is but maybe start saving up
Roenicke95stroker is offline
post #9 of 24 (permalink) Old 06-25-2014, 02:58 AM Thread Starter
That's not want I want to hear. Y'all think it would be a good idea to go ahead and change the fluid and filter?
post #10 of 24 (permalink) Old 06-25-2014, 05:49 AM
Mine as well, when you drop the pan check the fluid color and see if there is any pieces of metal or anything.
