ATF-2, DEX/MERC, DEX VI. E4OD - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-20-2014, 06:21 PM Thread Starter
I have an abundance of BMW fluid that is labeled ATF-2. Now I Cannot find anymore details on this so im wondering if its known rather or not this can be used in an E4OD. I also have DEX/MERC and DEX VI. Ive read a thousand forums with contradictory things and I just don't trust them. I'm just looking for a clear and definitive answer and what should be used. Thank you all for your time.
JMWRIGHT335 is offline
post #2 of 4 (permalink) Old 06-21-2014, 02:38 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: ATF-2, DEX/MERC, DEX VI. E4OD
I have never tested it, but I suspect that the BMW fluid will kill the E4OD. I know that Dexron VI will kill it. DEX/MERC is fine, that is what it was designed to use. MERCON V is also good. Anything else is death.
Mark
Mark Kovalsky is offline
post #3 of 4 (permalink) Old 09-24-2014, 07:11 PM
carl2591's Avatar
so mark this stuff will work in 4r100
Valvoline Dexron / Mercon Automatic Transmission Fluid: Motor Oil, Transmission Fluid & Car Lubricant : Walmart.com
but the mercon V is better.. is 5 a synthetic fluid and the dex/merc not?
carl2591 is offline
post #4 of 4 (permalink) Old 09-25-2014, 12:18 AM
Both MERCON and MERCON V are synthetic if you buy synthetic, and non synthetic if you buy non synthetic.
That fluid is probably fine. If they are still producing it to meet the now obsolete MERCON standard it's fine. If they changed it, maybe not. Who knows?
Mark
