ZF6 OIL QUESTION - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 06-20-2014, 06:07 AM Thread Starter
ZF6 OIL QUESTION
I KNOW ITS BEEN TALKED ABOUT BEFORE TIME AND TIME AGAIN. BUT WOULD THERE BE A PROBLEM WITH RUNNING LUCAS OIL STABILIZER IN THESE TRANSMISSIONS?? IM JUST LOOKING TO QUIET IT DOWN A BIT.. I HAVE IT HOOKED TO A 12V CUMMINS AND GOOD LORD THIS THING IS LOUD. IVE ALREADY DYNOMATTED THE ENTIRE CAB AND ITS STILL LOUD..
I WAS AT PARTS HOUSE THE OTHER DAY STANDING IN LINE WAITING TO CHECK OUT AND THEY HAD THE OIL STABILIZER FOR ENGINE OIL SITTING ON A SHELF AND I STARTED READING AND IT STATES ITS SAFE FOR ALL ATF FLUID ALSO NOT JUST ENGINE OIL.. THINK THE THINKNESS OF THE OIL WOULD HAVE A NEGATIVE EFFECT ON THE SYNCHROS?? I WANT TO QUIET IT DOWN BUT DONT HAVE THE $20 A QUART TO USE THE NEW FORD MANUAL TRANS FLUID FROM THE STEALERSHIP..
ALSO IS THE COOLER TOTALLY NECCESARY ON THESE TRANSMISSIONS?? IS THE TRANS REALLY EVER GOING TO GET HOTTER THAN WHAT THE ENGINE TEMPERATURE GETS?? ITS "COOLED" BY OIL FLOWING THROUGH THE RADIATOR.. COULD I JUST RECIRC IT BACK INTO THE CASE AND DELETE THE COOLER LINES?? THE GM VERSION DOESNT HAVE A COOLER ON IT..
THANKS
RICHARD
rjustman is offline
post #2 of 31 (permalink) Old 06-21-2014, 02:46 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: ZF6 OIL QUESTION
First, your caps lock key seems to be stuck. Please get it fixed, it's annoying reading something in all caps.
I don't know enough about the manual trans to know if the Lucas will help it or kill it. One or the other will happen.
The trans fluid IS cooled by flowing through the radiator. You don't need the quotes. I used to test transmission cooling for Ford and I know that the radiator cooler cools the transmission, it doesn't heat it to engine temperature.
The trans cooler is in the side of the radiator where the coolant has already been cooled. That is quite a bit cooler than engine temperature. If it was engine temperature, why have a radiator? The purpose of the radiator is to cool.
You can remove the cooler. You must know more than those of us that tested this and determined that the only way to make it last a long life was to keep it from getting too hot. Ford only added that cooler because it was fun, and we always tried to add things to the truck that wasn't needed so that we wouldn't make profits and Ford would go out of business. [/sarcasm]
At every auto manufacturer every penny is watched. Managers will kill to save a nickel. Do you think this cooler that cost several dollars would make it into production if it were not needed? Maybe GM doesn't care as much about how long the transmission lasts. Maybe their engines don't make enough torque to get the transmission hot.
Mark
Mark Kovalsky is offline
post #3 of 31 (permalink) Old 06-21-2014, 07:17 PM Thread Starter
If the cooler is only meant to cool why not have a fin type cooler that sits in front of the radiator only?? Its got to help maintain a temp not ONLY cool..or us guys that live in colder weather the oil would never heat up..manual transmissions don't create heat like an auto does..
GMs power output has been the same if not HIGHER than ford power outputs since the duramax has been in a gm frame so I know that's not the reasoning..
I'm not trying to stir chit I'm looking for a definitive answer..I've read both opinions..and I'm not doubting your expertise.I just know that I either need to quiet this beast down or get rid of it..its a good shifting trans but its to freaking loud...
Also my caps were on.that's how I write my reports at work so it looked normal to me at the time of typing..my apologies..thanks for your response its appreciated, at the end of the day I'll make my decision based of of your guys responses..this is my first rodeo in the ford world..
Thanks
Richard
rjustman is offline
post #4 of 31 (permalink) Old 06-21-2014, 07:51 PM
Administrator
Zmann's Avatar
this oil cooler discussion came up the other day
I was with the same opinion as Mark
Ford didn't do this as an advertising ploy " manual transmission now with cooler "
because no one would care
however it was mentioned ( just like the op noted ) this same tranny is used in other applications with no cooler
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 31 (permalink) Old 06-21-2014, 08:41 PM
Luddite in Charge
Mr_Andy's Avatar
The mindset that 'cooler must be better' is no doubt valid, but a few years ago I deleted one rather than fix the leak in the line and after I don't know how many miles it's still shifting/pulling/running fine.
Mr_Andy is offline
post #6 of 31 (permalink) Old 06-21-2014, 08:57 PM Thread Starter
I'm all for trying to keep things cool..has anyone ever put a gauge on one with the cooler and without..
rjustman is offline
post #7 of 31 (permalink) Old 06-21-2014, 11:27 PM
rusty1161's Avatar
I bet Mark has done that and more Mark knows more than we think - Ford Truck Enthusiasts Forums
Rusty
1997 F250 CC/SB 7.3 PSD 4X4 XLT, 248,000 miles
rusty1161 is online now
post #8 of 31 (permalink) Old 06-21-2014, 11:53 PM
Administrator
Zmann's Avatar
IMHO
because Air to oil depends on airflow and sometimes you have little to none
( but with no airflow you wouldn't expect a manual tranny to be working very hard )
the 5r that Mark worked on has both types of coolers in the same truck
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 31 (permalink) Old 06-22-2014, 12:37 AM Thread Starter
Yes 5 r have both in a series..I'm not doubting mark at all I'm sure he's a brilliant individual..but manual trannys are not the same animals as manuals..I think we'd all agree there..
Zmann.yeah obviously if you gave no air flow across the cooler up front it wouldn't cool..but at that point is idling in a parking lot putting strain on the truck haha
My truck still gas both coolers as it was an auto before I took the 6.0 out..my lines aren't leaking or anything but my radiator is cracked and when I change it i was thinking about taking coolers off..and maybe change out oils to the Amsoil synthetic or the ford stuff for 08+ zf6.. synthetics will help oil not break down under high temp IF in fact it gets hot while driving..
Let's keep this going..there seems to be a lot of what its with this trans..this is a good topic of conversation
rjustman is offline
post #10 of 31 (permalink) Old 06-22-2014, 12:56 AM
Administrator
Zmann's Avatar
Agreed !
DTR's Donation page
RIP DTR Ron
Zmann is offline
