What's the best clutch to buy???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 06-29-2009, 06:45 PM Thread Starter
<-•DEISEL CRAFT•
coalroller3x's Avatar
I have a 99 f- 350 with swamps chip. What is the best clutch to buy??
I'm looking at a south bend clutch kit and fly wheel for 900$ is that worth the money? It's rated 450hp 900 tq
05 f250
Cass 190cc injectors with 100 over nozzles
tsd fuel sump, fuel lab=Custom, sinister reg return, MPD headers/up pipes, arp studs,JGS wastegate, egr delete, banks CAC, ram air and techni cooler,S&B cold air,TurboNetics dual ball bearing 64/65 .83AR, twisted diesel trans stage 2,phantom 2=egt,trans,boost,fuel psi
coalroller3x is offline
post #2 of 24 (permalink) Old 06-29-2009, 06:46 PM
Hater Club
Dirk's Avatar
Re: What's the best clutch to buy????
con-ofe.
Porch Monkey. It's cool, I'm taking it back.
Dirk is offline
post #3 of 24 (permalink) Old 06-29-2009, 06:52 PM
Would that work if I wanted to truck pull every once in a while?
calebgriffin31 is offline
post #4 of 24 (permalink) Old 06-29-2009, 06:57 PM
HRT Performance
HotRodTractor's Avatar
The moment you say truck pull is the moment I say dual disk.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #5 of 24 (permalink) Old 06-29-2009, 06:58 PM
Hater Club
Dirk's Avatar
should be fine. You can step up to the FE.
Dirk is offline
post #6 of 24 (permalink) Old 06-29-2009, 08:40 PM
6.0 money pit
smokinstroker's Avatar
deff. dual disk if your pulling
smokinstroker is offline
post #7 of 24 (permalink) Old 06-29-2009, 08:42 PM
JHill's Avatar
you will not be competitive at all with a single, and if you try here what it looks like
A dual disk is worth the extra coin. and cost the same or less when it's rebuild time
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #8 of 24 (permalink) Old 06-29-2009, 09:03 PM
Banned
If you daily drive it..... don't sled pull it. Or get an auto.
Other than that, my 300 dollar clutch held over 540rwhp and plenty of people making less power have roasted the "better" clutch offerings out there, so pick your poison.
I had a guy local to me make mine. I'm sure it could still be had for a good price if somebody needed one.
Charles is offline
post #9 of 24 (permalink) Old 06-29-2009, 09:09 PM
Senior Veteran Member
Centxdiesel's Avatar
Garage
I just installed a Valair Ceramic-Kevlar conversion kit and flywheel and love it. Time will tell but to be rid of the dual-mass-> WOOHOO!
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #10 of 24 (permalink) Old 06-29-2009, 11:06 PM
Dieselgeek's Avatar
I had visions of sled pulling, and did this past weekend, so forked over the cash for a South Bend dual disc... Daily driving takes a bit to get use to, backing up wagons, and grain carts takes a toll on the foot after a bit though...
2002 F350 Reg Cab,4x4,7.3,6Spd.
Dieselgeek is offline
