e4od interchange...all 7.3l interchangeable? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 06-16-2014, 03:58 AM Thread Starter
Jjona5's Avatar
Send a message via AIM to Jjona5
I'm looking for a 4x4 e4od to go into my 78 ford with a 7.3l turbo idi. It currently has a 2wd e4od but the truck is a 4x4. While I'm looking on craigslist I see lots of powerstroke OBS and NBS trucks and I'm curious if I can use one of the newer ones.
1995 4 door dually Murdered out - 5 inch exhaust - down pipe - TS Chip with Tunes by Cale - 5 speed - Banks Pipe Kit and 7.3l aluminum end intercooler - Adrenaline HPOP - D66 - Rosewood Stage II(160/80) injectors, Gutted EBPV - Blank Ped - EGT Gauge - Boost Gauge - Homebrew Regulated Return E-Fuel
Looking for a Single Cab long bed OBS 4x4
Jjona5 is offline
post #2 of 8 (permalink) Old 06-16-2014, 12:39 PM
whistle tits
ghohouston's Avatar
Re: e4od interchange...all 7.3l interchangeable?
I don't think you could use a 4r100 or newer trans without a lot of wiring, and even then, I think they're pcm controlled, so you still would probably be out of luck.
ghohouston is offline
post #3 of 8 (permalink) Old 06-16-2014, 03:08 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
The E4OD is also PCM controlled.
You can use any E4OD or 4R100 from a 7.3L diesel. There are a few differences year to year, so some minor wiring changes may have to be made, or the solenoid body will have to be swapped.
Mark
Mark Kovalsky is offline
post #4 of 8 (permalink) Old 06-20-2014, 01:37 AM
whistle tits
ghohouston's Avatar
ahh thanks mark, wasnt sure on the e40d.
post #5 of 8 (permalink) Old 06-21-2014, 02:47 PM
The name E4OD means Electronic 4 speed Over Drive..
Mark
post #6 of 8 (permalink) Old 07-20-2014, 11:10 PM Thread Starter
Jjona5's Avatar
I picked up a 95 e4od with transfer case to go onto my 92 7.3l IDI that will be going in a 78 ford f150 4x4 ).
Jjona5 is offline
post #7 of 8 (permalink) Old 07-20-2014, 11:32 PM
cpdad93's Avatar
I think freight to leatherneck is going to make it unaffordable.
cpdad93 is offline
post #8 of 8 (permalink) Old 07-21-2014, 01:05 AM Thread Starter
Jjona5's Avatar
Hah well I'm back in the real world now. I haven't updated it. I drove to Austin and picked it all up. Can't wait to get the truck going. I'm going to need to strip down the harnesses and integrate it into my 78 but it shouldnt be hard. I do plan on keeping the cruise control!
Jjona5 is offline
