5r110 shift problem tow/haul on off blinking - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 06-14-2014, 08:03 PM Thread Starter
Driving from work to my home and my tow/haul stared blinking and it was shifting rough for a min and then it stop and wouldn't let me go to overdrive and every time i I hit the button the rpm would go up and try to shift and it wouldn't shift any ideas on wat the problem maybe I'm not that good with diagnosis of transmissions
hillbilly92x is offline
post #2 of 16 (permalink) Old 06-14-2014, 08:08 PM
Administrator
Zmann's Avatar
Re: 5r110 shift problem tow/haul on off blinking
that flashing light means u have a code you can read
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 16 (permalink) Old 06-14-2014, 09:45 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
The places that read codes free won't be able to read these codes. You need either a good independent shop or a Ford dealer. Without the codes all I can tell you is that something is wrong.
Mark
Mark Kovalsky is offline
post #4 of 16 (permalink) Old 06-14-2014, 10:50 PM Thread Starter
I got code p2703 and I got one for gear ratio incorrect
post #5 of 16 (permalink) Old 06-14-2014, 11:00 PM
Administrator
Zmann's Avatar
interesting
how does your truck know what gear ratio it has ?
what exact truck do you have ? and what other code do you have ?? and maybe a little history like miles and maintenance ?
it may help someone help you
the p2703 is transmission element d apply time performance according to My A/E software
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 16 (permalink) Old 06-14-2014, 11:11 PM Thread Starter
I have a 04 f350 I don't know the transmission ratios I had some work done to it about a month ago I had a new hpop and 100 hp injectors installed all on a stock set up then I just installed a k&n high performance intake and a 5 in mbrp turbo back exhaust system n that's all the aftermarket parts I have on it they also put a trans tune on it so idk if that is affecting it or not my truck has 198k on it it also threw a ecm keep alive memory code I was at work today and I load tested my battery due to the battery light kept coming on
post #7 of 16 (permalink) Old 06-14-2014, 11:35 PM
Administrator
Zmann's Avatar
the KAM code was it a p1000? that would be normal for disconnecting the batteries if you unhooked both at the same time
the grear ratio code can't be correct IMO since the truck has no way of knowing what ratio you have
the work you had done to the trany and the programing they did is a point of concern IMO and 200k is a lot of miles for a trany
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 16 (permalink) Old 06-15-2014, 01:12 AM
matthewd11's Avatar
Your direct drive clutches are probably on their last legs. Element D is direct drive. The PCM will throw an incorrect gear ratio code if it doesnt see the correct RPM rate of the internal components for any given gear. I'm guessing gear 5 incorrect ratio, OP? Do you have a delay going to reverse? Or does it slip the 3-5 shift?
Where are you located?
matthewd11 is offline
post #9 of 16 (permalink) Old 06-15-2014, 01:51 AM Thread Starter
Idk about the delay in reverse but it does jerk n 3 and rup
post #10 of 16 (permalink) Old 06-15-2014, 01:52 AM Thread Starter
Michigan
