Trouble with my trans - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 06-26-2009, 07:32 PM Thread Starter
Burger Flipper
Today my transmission started acting funny.
Example: Start truck, no OD light flashing, drive home from work, no OD light, go to put it in park, revs up to about 1500 and comes back down, OD light flashing now.
Turn truck off and back on...no OD light, put it in drive, put it in park, revs up again, OD light flashing...what gives?
I would/plan on getting the codes pulled, but I have to take off "the cure" first before they can troubleshoot it.
Just wondering if anyone has encountered this before. Thanks in advance.
2000 F250 Lariat SC 4X4, aFe 2 PG7, MBRP 4" SS Duals w/muffler delete, Dipricol gauges, 203* T-stat and billet housing, Dieselsite Coolant filter, 6.0 intercooler...07 Harley Lights, 5K retro-solutions HIDs, ITP pre-pump kit, Harpooned, "The Cure"
J_F250 is offline
post #2 of 13 (permalink) Old 06-26-2009, 10:33 PM Thread Starter
Burger Flipper
Re: Trouble with my trans
OK got the codes pulled at the dealer.
P0720 OSS sensor circuit fault
He told me that this had nothing to do with the motor revving up though.
P1670 electronic feedback signal not detected
P0541 air intake heater-probably because it is gone-lol
P0470 exhaust back pressure??
quoted me $120 to fix the OSS sensor
Tell me what you guys think.
Thanks
J_F250 is offline
post #3 of 13 (permalink) Old 06-26-2009, 10:54 PM
Everybody poops <~ see?
dennisr_f350's Avatar
Send a message via MSN to dennisr_f350
Do have a shift kit installed, line pressure adjustments, and trans mods? sounds to me like a flow restriction, as if your tc is slow to unlock. what does the fluid look like, very dark?
2007
F350 SuperDuty
Some air
Some fuel
Some grip
Some guages
The usual suspects.
dennisr_f350 is offline
post #4 of 13 (permalink) Old 06-27-2009, 01:10 AM Thread Starter
Burger Flipper
No... fluid good (Amsoil) changed in October last year. Trans has not been above 180* since change and just got there in the last few days with the weather. The only trans mod I had was "the cure" but I took it off so I could get the codes pulled and no change to the way it is acting.
J_F250 is offline
post #5 of 13 (permalink) Old 06-27-2009, 01:23 AM
To be honest, and you likely wont like this, but my first step would be to return to a factory fluid, in your case, Ford Mercon V. In some cases, OEM fluid can make all the difference in a transmission. After that, check that the TCC lock-up switch is sending/recieving signals correctly. If possiable, drive the truck with an OBDII diagnostic scan tool, and monitor the transmissions lock-up status, input/output rpm's, and flow rates.
These tips may be outlandish, but these are the steps I would take if you brought your truck into the dealership I work at.
2007
F350 SuperDuty
Some air
Some fuel
Some grip
Some guages
The usual suspects.
post #6 of 13 (permalink) Old 06-27-2009, 01:32 AM Thread Starter
Burger Flipper
Ok...I am a little stumped on what to say.
When I said the service advisor told me that the sensor had nothing to do with the revving up, that was a DA move on him because I am positively certain that is the trouble. They absolutely are retarded up there. He was telling me that I had a O2 sensor on it and that was the reason for the EBP code..lol
Where is the "OSS sensor located" maybe that is a clearer question
J_F250 is offline
post #7 of 13 (permalink) Old 06-27-2009, 02:24 AM
The output shaft speed sensor is one the drivers side of the 4R100, almost centred on the side of the transmission case. It's a forward facing sensor, with four wires to it.
I could be wrong, as I am a transmission technician, at a Dodge dealer.
2007
F350 SuperDuty
Some air
Some fuel
Some grip
Some guages
The usual suspects.
post #8 of 13 (permalink) Old 06-27-2009, 03:53 AM Thread Starter
Burger Flipper
Ok thanks for the help man.
J_F250 is offline
post #9 of 13 (permalink) Old 06-27-2009, 10:18 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
The OSS is on the rear of the trans at the top. It has two wires to it.
Mark Kovalsky is offline
post #10 of 13 (permalink) Old 06-27-2009, 12:47 PM Thread Starter
Burger Flipper
Thank you sir
J_F250 is offline
