E40D problem help!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 06-07-2014, 10:44 PM Thread Starter
Roenicke95stroker's Avatar
E40D problem help!!
Just driving around today then On my way home truck wouldn't shift out of 1st and wouldn't pull up my driveway. Temp gauge said it was at 205* what could this be!!!
Roenicke95stroker is offline
post #2 of 12 (permalink) Old 06-07-2014, 11:46 PM
JSchuricht's Avatar
Re: E40D problem help!!
Start by checking the fluid level. Beyond that plan on a new trans. You will have to pull everything apart to find what broke. It could be anything from a bad torque converter, bad seal, bad solenoid, etc but many of those items take out everything else too.
JSchuricht is offline
post #3 of 12 (permalink) Old 06-07-2014, 11:51 PM Thread Starter
It will move but I have to rev the engine up real high and it doesn't have the strength to make it up my driveway
post #4 of 12 (permalink) Old 06-08-2014, 12:58 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
It's done. You need either a rebuild or a new transmission.
Mark
Mark Kovalsky is offline
post #5 of 12 (permalink) Old 06-08-2014, 01:18 AM Thread Starter
I can get a rebuild kit for 300$ at autozone would it be worth it?
post #6 of 12 (permalink) Old 06-08-2014, 01:48 AM Thread Starter
Would an E4OD out of a 95 460 work?
post #7 of 12 (permalink) Old 06-08-2014, 04:03 PM Thread Starter
Bump
post #8 of 12 (permalink) Old 06-08-2014, 04:54 PM Thread Starter
Sorry it's a 1993 f350 460, would the tranny be the same as mine?
post #9 of 12 (permalink) Old 06-09-2014, 01:50 AM
A 460 and a diesel have different rear face of block bolt patterns. A trans from a 460 won't bolt to a diesel.
Mark
post #10 of 12 (permalink) Old 06-16-2014, 03:28 AM Thread Starter
So took my tranny to a repair shop, needs a rebuild. Going ahead and buying a bts stage 2
