6.0 tranny issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-25-2014, 12:09 PM Thread Starter
rtc0360's Avatar
6.0 tranny issue
All,
I have an 03 f250 with 6.0. I have added studs and changed head gaskets. I pulled motor out of truck. Did head gaskets. Put back together. Now the engine idles rough. Tranny has also been shifting funny hesitating to shift, before motor rebuild shifting was fine and ran good. Yesterday(after running around town) the truck will not go in reverse. If I put it in neutral the tranny is in gear. When I put motor back together I had an issue of the shaft between the torque converter and the tranny being jammed. Had to pull motor back out and pry the torque converter and shaft back out. Then slide shaft in and then the torque converter and all seemed good. Sometimes the dash shakes so bad that I think it is going to come off. Any help would be appreciated as always. Thanks for looking.
rtc0360 is offline
post #2 of 7 (permalink) Old 05-25-2014, 12:54 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 6.0 tranny issue
I think you need to take the trans out and rebuild it. I suspect that when you jammed it together the torque converter was damaged and the pump was destroyed. Sorry.
Mark
Mark Kovalsky is offline
post #3 of 7 (permalink) Old 05-25-2014, 04:52 PM Thread Starter
rtc0360's Avatar
Thanks Mark,
I was hoping you would chime in. When I bolted the motor to tranny the first time, I placed the shaft into the torque converter and then into the tranny. I then proceeded to bolt the flex plate to the torque converter. Afterwards I could not rotate the engine so I figured something was wrong. When I pulled the motor back out I could not pull the torque converter out easily and had to pry to get it loose. That is when I placed the shaft into tranny and then put the torque converter and the bolted to flex plate and everything turned and so on. In rebuilding the tranny, do you feel that this needs to be done by a tranny shop or could I possibly have success in it(I pulled motor out and replaced head gaskets on my own)? If not could you recommend a rebuild shop? If you think I could rebuild, what kit would be recommend? Where can I get a step by step for rebuild? Thanks for your reply. I think I have an injector issue as well.
rtc0360 is offline
post #4 of 7 (permalink) Old 05-25-2014, 05:58 PM
The step by step is available in a manual from https://www.atsg.us/atsg/. You should have no problem doing it.
When installing the converter turn the trans so that the bellhousing is facing up. Install the shaft into the trans, then the converter onto the shaft. Rotate the converter around and around until it drops all the way in. The face of the converter must be below the front face of the bellhousing.
I've bought kits from http://www.transtar1.com/ with good results.
If you want someone to do it for you I know a good transmission shop in Ocala, FL.
Mark
post #5 of 7 (permalink) Old 05-25-2014, 08:00 PM Thread Starter
rtc0360's Avatar
Thanks a lot for the info. Started pulling drive shafts off today. I plan on pulling the transfer case off then pulling the tranny. Am i doing a bad thing by pulling transfer? I don't have a lift and am doing this on the ground. I have a motorcycle jack to lower both the transfer and tranny. What is the name of the shop in Ocala?
rtc0360 is offline
post #6 of 7 (permalink) Old 05-26-2014, 01:33 AM
A1 Transmission. Paul and Steve Camargo are the owners. Tell them I sent you.
They are a mile or so south of downtown just off 441.
Mark
post #7 of 7 (permalink) Old 05-28-2014, 01:27 PM Thread Starter
rtc0360's Avatar
I have started the process of pulling the trans out. Took the transfer off first then the trans. Attached is a PDF of some pics. Let me know what you guys think. I haven't seen any thing that stands out that indicates any problems. I have trans going to a rebuild shop today. I have been debating if I shoud rebuild myself or not. I don't have the time to learn so I may get the shop to rebuild.
rtc0360 is offline
