wont hold a gear - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-22-2009, 09:13 PM Thread Starter
splitshot's Avatar
wont hold a gear
my 2000 PSD with a auto wont hold a gear down a hill except in overdrive,
if I pull it out of overdrive or 2nd or 1st it wont hold the truck back and acts like its in neutral. if I give it throttle if goes fine, just wont hold the truck back.
I had a different truck a few years back that did the same thing, other than that
everything works great.
what do you think? programming, bad coast clutch
the truck is all stock and has 100k on it, I was going to do a torque converter lock up switch, is this going to correct the problem?
thanks for your help in advance.
2000 PSD crew 4x4
splitshot is offline
post #2 of 5 (permalink) Old 06-24-2009, 01:26 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: wont hold a gear
It's the coast clutch. The only way to fix it is to take the trans out and fix the coast clutch. It isn't in the torque converter, so nothing you do with the converter lockup will make any difference.
Mark Kovalsky is offline
post #3 of 5 (permalink) Old 06-24-2009, 05:22 PM Thread Starter
splitshot's Avatar
so what is holding the truck back while its in overdrive?
am I doing damage to the trans to let the truck basicly coast down a hill at slower speeds 30-40 MPH when its not in overdrive?
what does it take to make it act like a manual trans, I would like full control of shifting and TC lockup, say Im headed up a hill with a load in overdrive and want to mash the throttle with out it down shifting or unlocking the converter. is there a correct way to accomplish this? Thanks.
2000 PSD crew 4x4
post #4 of 5 (permalink) Old 06-27-2009, 10:27 AM
The overdrive clutch is holding it back in overdrive. When the trans is in the lower three gears the overdrive clutch is off and the overdrive one way clutch overruns on decels. Applying the coast clutch locks the overdrive one way so that there is hold back. The overdrive clutch does this in fourth gear.
You need either a custom chip or an aftermarket trans controller to replace the PCM to do what you want.
post #5 of 5 (permalink) Old 06-27-2009, 10:10 PM
tbolt's Avatar
DPTuner with the decell tune works great!!
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
