5r110 problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 05-21-2014, 09:57 PM Thread Starter
5r110 problems
I have a 2006 4wd with around 225k miles on it. The issue I am having is when the transmission is shifting from 3 to 5 (according to my sct livewire) the transmission seems to be slipping. If the truck is run hard then there is no slipping. I noticed today that when shifted from Park to drive or Reverse that it would take 5-10 seconds for the transmission to engage. I have checked the fluid and everything seems good. I was wondering if one of the solenoids are bad? The SCT is not showing any transmission codes. I am taking it in tommrow for a complete service. If anyone can give me some help or have seen this issue before I would love some help. I need to tow my boat to the lake this weekend.
jamcconnell2 is offline
post #2 of 6 (permalink) Old 05-22-2014, 05:43 PM
matthewd11's Avatar
Re: 5r110 problems
replace your line pressure solenoid (PC-A). The solenoid body needs to be removed to do this. The low/reverse solenoid could also be a possible cause of the engagement delay. I also have seen sticky valves in the pump, specifically the main pressure regulator valve. This is usually due to metal intrusion. Does the truck slam into gear when it engages? Or just drop in? As far as the 3-5 shift issue, could be a learn issue, or a problem with the direct drive solenoid or direct clutch. Is there an RPM flare? I notice that every once in a great while on my truck, at feather throttle, the PCM releases the intermediate clutch too soon resulting in a RPM flare. At WOT it shifts absolutely perfectly. My truck is tuned and a semi-built trans. I would pull the pan and check for any metal debris. Make sure you change the inline filter. If you need a rebuild i build them.
matthewd11 is offline
post #3 of 6 (permalink) Old 06-03-2014, 12:42 AM
Re: 5r110 problems
I am having the same issues with my trans right now
2004 4door long bed 6.0 upgraded standpipes and dummys, blue spring, new heads, studs, egr delete, uppipes, brp street runner tune, 37" tires, stock trans, scangauge, egt, boost, trans temp
Murdered6.0 is offline
post #4 of 6 (permalink) Old 07-30-2015, 01:13 AM
Re: 5r110 problems
Update: I think that it's stuck in an upper gear. It won't go into a lower gear even if I try to do it manually on the gear selector.
dannyb347 is offline
post #5 of 6 (permalink) Old 07-30-2015, 01:16 AM
Administrator
Zmann's Avatar
Re: 5r110 problems
update to what ??
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 6 (permalink) Old 07-30-2015, 02:37 AM
Re: 5r110 problems
Sorry I clicked on the wrong post.
