5R110 issues after fluid change ? Fluid change tricks ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 05-21-2014, 06:02 PM Thread Starter
me2
I have a job 1 2008 with a 5R110 with 160K on it. It pulls a big 5er about 1,000 miles a year and other than that does a ton of cruising at 65 MPH.
Its way overdue for a transmission fluid change. I'm afraid that changing the fluid is going to screw up the operation (shifting) of the transmission. Am I being paranoid ?
Are there any tricks other than dropping the pan and replacing the fluid ?
Thanks
New truck.
08 F350 King Ranch
Long box CC 4x4
6.4 5R110
Soon to get a Cummins 6.7 transplant.
Old truck.
Red '99 2WD F250 CC SWB
3rd gen 325/610 Cummins, ZF6
Custom air ride suspension
me2 is offline
post #2 of 21 (permalink) Old 05-22-2014, 02:44 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 5R110 issues after fluid change ? Fluid change tricks ?
Yes, you're being paranoid. New fluid can only help a good transmission. It can't fix a broken one, so if the trans is dying new fluid isn't going to save it.
On a Job 1 truck you have a filter in the trans cooler line. It's important to change that filter. The internal filter is good for the life of the trans,
Only use MERCON SP or MERCON LV fluids.
Mark
Mark Kovalsky is offline
post #3 of 21 (permalink) Old 05-22-2014, 02:52 PM Thread Starter
me2
Thanks, Mark.
New truck.
08 F350 King Ranch
Long box CC 4x4
6.4 5R110
Old truck.
me2 is offline
post #4 of 21 (permalink) Old 05-22-2014, 03:13 PM Thread Starter
me2
The shop manual (page 307-01-190) seems to recommend a simple drain via the trans drain plug with a refill via the dipstick tube.
I was thinking of dropping the pan to inspect for debris and replacing the transmission pan filter as well. Should I do this ?
If one does a simple drain, its going to leave trans fluid in the cooler circuit and and in the TC. Is there a simple way to drain the oil from these ?
Refilling via the dipstick sounds painful. Any other ideas on refilling ?
Thanks
New truck.
08 F350 King Ranch
Long box CC 4x4
6.4 5R110
Old truck.
me2 is offline
post #5 of 21 (permalink) Old 05-22-2014, 04:31 PM
No, the only way to drain them is removal. Or you could flush the system. Some people get the bigger pan and put the job 3 filter in. I guess they are supposed to be better.
Lipka101 is offline
post #6 of 21 (permalink) Old 05-22-2014, 04:33 PM
Oh and refilling isnt bad through dipstick tube. It's the only way to do it. Just need a funnel small enough to fit in the tube.
Lipka101 is offline
post #7 of 21 (permalink) Old 05-22-2014, 05:11 PM Thread Starter
me2
Has anyone flushed the in radiator cooler and external cooler with air ?
On my Job 1 2008, the lines going to and from the filter go to these coolers. Would there be a problem if I put a LITTLE air pressure on one of the lines to blow out the fluid in them ?
New truck.
08 F350 King Ranch
Long box CC 4x4
6.4 5R110
Old truck.
me2 is offline
post #8 of 21 (permalink) Old 05-23-2014, 12:39 AM
Administrator
Zmann's Avatar
it's been done with good results but they didn't go nuts with the psi
the procedure netted a few more quarts discharged
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 21 (permalink) Old 05-23-2014, 01:02 AM
Luddite in Charge
Mr_Andy's Avatar
I can hardly disagree with a person bearing your credentials, but I was under the impression that the internal filter was smaller on job 1 vis-a-vis the updated 2 and 3's. Couple this with the fact that the cooler circuit only opens and runs at a certain elevated temp. In theory then wouldn't the inline filter see less use than the in-pan and therefore bear less load, making the smaller pan filter get more of the crud?
Again, in no way am I disagreeing with you - in fact I hope you confirm that I'm wrong and I only have to crack two lines instead of dropping a pan and taking a bath... I'm at 27k so it's about time for that / those filters. Hopefully now it's singular tense tho
What's the difference between the SP and LV fluids?
Mr_Andy is offline
post #10 of 21 (permalink) Old 05-23-2014, 01:03 AM
I don't recommend it. There is no reason to replace the internal filter.
No, there is not.
The only other way I can think of is to turn the truck over and fill it through the drain plug in the pan.
The dipstick is the only way to fill an automatic.
You were correct until you said the internal would get more of the crud. The earlier internal filter is too coarse to get anything but the largest chunks. Most of what needs to get filtered out passes right through the internal filter.
Any internal filter older than Job #2 2008 is good for the life of the trans. It never needs to be changed until the trans is rebuilt.
I dunno. MERCON LV came out after I left Ford. I don't know anything about it other than it was supposed to replace MERCON SP.
Mark
