ZF6 flywheel in front of ZF5? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-28-2014, 04:20 AM Thread Starter
Mr. Bob's Avatar
My buddy is doing a ZF5 swap in his 1995 F250. I have a stock 7.3 ZF6 flywheel. With the correct clutch disc could he use this in his swap?
Thanks
Bob
1995 Ford F350 XLT CC LB, 4X4, 12V Cummins, ZF5, D60, Sterling 10.5, 6637 air filter, 7.3L Intercooler, Autometer Cobalt Gauges. ZF6 swap soon to come
Mr. Bob is offline
post #2 of 5 (permalink) Old 05-04-2014, 11:21 PM
International Coal Roller
jbwaldrop88's Avatar
Re: ZF6 flywheel in front of ZF5?
No, I think the zf6 flywheel has the wrong tooth count
02 250 CCLB, 6 spd, PHP Phoenix, ISSPROs, AFE/6637 intake, 4" DE straight exhaust, WW, coolant filter with ELC, AIH delete, ebpv delete, bellowed uppies, 4" on 35's and racelines
jbwaldrop88 is offline
post #3 of 5 (permalink) Old 05-04-2014, 11:24 PM
97250HD's Avatar
Yes you can use it. A valair 13" replacement clutch will bolt to it also.
I have a SD flywheel with a valair 650hp ceramic single in my 97.
97 F250 eclb. 265k
- Fresh engine. d60. zf5. Some other stuff...
E99 f550 213k
- starts every morning...
97250HD is offline
post #4 of 5 (permalink) Old 05-05-2014, 06:22 AM Thread Starter
Mr. Bob's Avatar
Awesome! Thanks for the reply! That's really good news.
Any other mods needed? Or is it bolt up and go?
Mr. Bob is offline
post #5 of 5 (permalink) Old 05-05-2014, 10:40 AM
97250HD's Avatar
The dowel pins on the flywheel from the SD clutch need to be removed as they don't line up. Besides that it bolts in.
Use a normal OBS 13" replacement clutch for a solid flywheel. Not a SD clutch.
97 F250 eclb. 265k
E99 f550 213k
97250HD is offline
