Trans. Fluid mark - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-27-2014, 12:23 AM Thread Starter
Trans. Fluid mark
Just had dealer do a trans fluid flush and external filter change on my 03 6.0 and I got home after running for about hour and half and I check fluid level and it was only half way up on the cold mark. So is this the new norm. Or did he not put enough in it? Any info will be great.
Deerslayer94 is offline
post #2 of 12 (permalink) Old 04-27-2014, 12:28 PM Thread Starter
Re: Trans. Fluid mark
And after sitting all night I checked it cold and it's little above full line on dip stick. Any thoughts
post #3 of 12 (permalink) Old 04-27-2014, 02:04 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
My thoughts are that there is NOTHING to be learned by checking the fluid cold. The person that put a COLD mark on the dipstick was a dipstick himself.
If it is on the cold mark with the transmission cold all you know is that the level is several quarts low, or maybe right, or maybe even high. It's one of those three.
Warm the trans up by driving at least 10 miles and check it again idling in park.
Mark
Mark Kovalsky is offline
post #4 of 12 (permalink) Old 04-27-2014, 03:59 PM
Administrator
Zmann's Avatar
old acquaintance of yours?
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 12 (permalink) Old 04-27-2014, 04:58 PM
No, I actually don't know who designed it. But I've seen the dipstick. It had to have been designed by a dipstick.
Mark
post #6 of 12 (permalink) Old 04-27-2014, 05:02 PM Thread Starter
Ok I checked it after running in for 10 miles and it's still halfway up the cold mark. So should I add some in there
post #7 of 12 (permalink) Old 04-28-2014, 02:30 AM
It should be in the cross hatched area that says DO NOT ADD. If it is below this, add fluid. Use only MERCON SP or MERCON LV. Anything else is trouble.
Mark
post #8 of 12 (permalink) Old 04-28-2014, 11:51 PM Thread Starter
Ok got it thanks man.
post #9 of 12 (permalink) Old 04-29-2014, 12:08 AM
'05 Excursion
Term3's Avatar
Seriously considering putting a sight port on the side of my ATF deep sump pan because it usually takes me at least six tries to figure out the level on the stick. Like the ones on AFE differential covers.
Sent from AutoGuide.com App
Term3 is offline
post #10 of 12 (permalink) Old 04-29-2014, 03:51 AM
rusty1161's Avatar
Mark,
Is this true for the E4OD/4R100, too?
Thank you.
Rusty
1997 F250 CC/SB 7.3 PSD 4X4 XLT, 248,000 miles
rusty1161 is offline
