TC unlocking in OD - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 06-14-2009, 04:00 AM Thread Starter
ADubDiesel's Avatar
TC unlocking in OD
So I have noticed that my torque converter does not stay locked in OD at highways speeds. I can be doing 75 then let off and my rpm immediatly drops down from 2000 to about 1500. Trans doesn't seem to be slipping at all. Need to check the fluid but it was fine about 2 months ago. TC going out? Was looking to get a valve body pretty soon.
1995 Ford F-250 7.3 (Sold)
1998 Nissan Maxima 3.0
ADubDiesel is offline
post #2 of 19 (permalink) Old 06-14-2009, 12:40 PM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Re: TC unlocking in OD
Which one of your trucks do this?
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #3 of 19 (permalink) Old 06-14-2009, 12:49 PM
OBS junkie
Cat_Rebel's Avatar
Moved this to the correct section, carry on.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #4 of 19 (permalink) Old 06-14-2009, 02:46 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
That's normal. When you let off of the go pedal the torque converter is supposed to unlock.
Mark Kovalsky is offline
post #5 of 19 (permalink) Old 06-14-2009, 09:06 PM Thread Starter
ADubDiesel's Avatar
It's on the 95 so an E4OD. I thought in overdrive the torque converter was supposed to stay locked?
post #6 of 19 (permalink) Old 06-14-2009, 10:18 PM
Austinj427's Avatar
You sure about that? I use mine on the highway to slow the truck down in the hills
Austinj427 is offline
post #7 of 19 (permalink) Old 06-14-2009, 11:00 PM
theSLEEPER's Avatar
Mine does that... Like if I'm going 70 and I let off with my manual tc switch engaged... I think it's GOTTA be normal.
theSLEEPER is offline
post #8 of 19 (permalink) Old 06-15-2009, 10:44 AM
Yes, I'm sure. You don't need the torque converter locked to use the engine to slow the truck.
post #9 of 19 (permalink) Old 06-15-2009, 12:46 PM
PHPDiesel's Avatar
You probably noticed this on the 95 as opposed to the 01 in your signature after driving each one.
Yes, the 95 will do that if it's still got stock programming. Your 01 will likely (depending on PCM code) leave the TC locked on decel down to 30 MPH. It will stay locked through the 4-3 downshift at 40 MPH...even if you hit the brakes.
The best you'll ever get for your 95 will be a TC clutch that stays locked at 0% APP (accelerator pedal position) on decel but will unlock as soon as you hit the brake pedal.
Cody
PHPDiesel is offline
post #10 of 19 (permalink) Old 06-15-2009, 04:32 PM
theSLEEPER's Avatar
I'm gonna have to take a video....
