dp/tricumulator - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 06-11-2009, 01:43 AM Thread Starter
2000SD's Avatar
dp/tricumulator
I have a dp tuner and the line pressures were brought up to compliment a jon woods vb I went in another direction and got the sonnex kit with the 3 springs instead of the vb
Do you guys think that the installation of the springs would give me an excessive hard shift at light throttle positions?
Another issue I have is that I mistakingly bought the mercon 5 and I'm assuming that It has 3 in it how much of the residual3 could be mixed with the 5
or just return the 5 Thanks for your inputs guys tom
2000 PSD CC SB 2WD AUTO 3.7 140K ITP reg return, afe,magnaflow3.5down4''back, foil delete, zoodad mod, hpx,.450 sonnax mod, DP 80e 80t F-5, autometer pyro,boost, AE monitored
2000SD is offline
post #2 of 2 (permalink) Old 06-11-2009, 01:47 AM
Re: dp/tricumulator
The Sonnax spring kit will cause the shifts to be firmer than the stock springs. Be sure to note which stock springs go where so that you can replace them if necessary.
Tinscout is offline
