changin my trans fluid - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 10-29-2007, 06:58 PM Thread Starter
got an 05 auto...what are some of you guys running and how many quarts? how easy is this to do? never done it before.
mxchase is offline
post #2 of 15 (permalink) Old 10-30-2007, 07:57 PM Thread Starter
Re: changin my trans fluid
hello? anyone?
mxchase is offline
post #3 of 15 (permalink) Old 11-01-2007, 03:54 AM
Race car driva.......
bigblockhorse's Avatar
Mercon SP would be the proper fluid. Pan drop is approx 7-9 quarts, get more if you plan to flush it.
bigblockhorse is offline
post #4 of 15 (permalink) Old 11-01-2007, 06:05 PM Thread Starter
okay. mercon SP...is there any real good synthetic? like try Amsoil?
how do i go about flushing it?? sorry for the newb questions..never touched a tranny before.
so is there just a drain bolt- i imagine on the bottom somewhere
and filling it up? is that in the engine compartment?
how do i flush?
mxchase is offline
post #5 of 15 (permalink) Old 11-01-2007, 06:10 PM
OBS junkie
Cat_Rebel's Avatar
I'm not sure if the 6.0L have a drain plug or not.
One thing I do that always seems to help is to dump a quart of Lucas Trans-Fix into the pan before I put it in. It's about as thick as maple syrup so if you try to pour it down the tube it will plug it up for a while. Always shift like a caddy for me!
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #6 of 15 (permalink) Old 11-01-2007, 06:13 PM Thread Starter
SO YOU PUT the lucas trans fix in then drain it out? then add your regular tranny fluid?
mxchase is offline
post #7 of 15 (permalink) Old 11-01-2007, 06:36 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
I sure wouldn't put ANYTHING except MERCON SP into a TorqShift trans!!!!!!!
Those solenoids are VERY sensitive, and adding something like the Lucas MIGHT cause some VERY expen$ive damage!
The only MERCON SP fluid that I know of is Motorcraft brand. It is a synthetic.
Mark Kovalsky is offline
post #8 of 15 (permalink) Old 11-01-2007, 06:40 PM Thread Starter
thanks!
mxchase is offline
post #9 of 15 (permalink) Old 11-02-2007, 12:43 AM
OBS junkie
Cat_Rebel's Avatar
Didn't think about that one, I'm so used to running E4ODs or 4R100s, it does make sense though.
RIP Will Iott
post #10 of 15 (permalink) Old 11-02-2007, 04:44 AM
Laces Out
bigrpowr's Avatar
no he said put it in the pan before you bolt the pan back on. dont flush it out. just give me a call chase ill help you do it. its real simple. you need to get a tranny filter as well.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
