Valvebody Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 07-25-2007, 05:31 PM Thread Starter
Valvebody Question
Ok, I'll try to make it short and simple.
I hate my FTVB.
I want to rebuild it with my own stuff.
I want to be able to run at stock line pressure.
I want frim, crips shifts, not slamming.
What should I add to make the perfect valve body?
I've heard transgo tugger kit with the plate, and .427 line mod.
How should I set it up for my HP level? Let's guess 380-400rwhp
Thans
gregrob is offline
post #2 of 27 (permalink) Old 07-25-2007, 09:09 PM
HP Junky
Re: Valvebody Question
What about calling John Wood? I bet he could answer some questions for ya...
RockinJW is offline
post #3 of 27 (permalink) Old 07-25-2007, 10:51 PM
Race car driva.......
bigblockhorse's Avatar
send it to me, I'll pull that ftvb crap out and stick some good stuff in it.
Seriously, the vb runs at stock pressure, you have to raise it in the pump or with a chip, the vb (acummulator is the correct term) just affects shift duration and firmness.You could try replacing the line mod with a std .372 valve, pull the inner springs in each of the three bores (Leave the outer)
If its still to rough we will need to take other measures, but this should calm it down some.
bigblockhorse is offline
post #4 of 27 (permalink) Old 07-25-2007, 11:01 PM Thread Starter
Oh he already did, you heard it too .
It's me just tryin to be cheap and DIY, like I always am...
gregrob is offline
post #5 of 27 (permalink) Old 07-25-2007, 11:01 PM Thread Starter
Thanks John, I'll be in touch
gregrob is offline
post #6 of 27 (permalink) Old 07-26-2007, 01:57 PM
Bill
badford350's Avatar
what exactly is it that you dont like about the ftvb? Sounded like if you kept stock programing in the transmission they worked fine. Its just you make me nervous about putting mine in. I just got it in the mail.
02 f350 larit, itp rr & pre pump filter, GTP38r, international up pipes, swamps 175/146 single shot's, DP tuner, factory tech valve body & lot of extra lights
badford350 is offline
post #7 of 27 (permalink) Old 07-26-2007, 11:05 PM Thread Starter
No, if you keep stock programming in the transmission, it will jar your teeth.
Line pressure is removed to try and tame the hard shifts, and it's still way too hard.
Plain and simple, it shifts too hard, and it's inconsistent.
gregrob is offline
post #8 of 27 (permalink) Old 07-27-2007, 02:10 PM
Bill
badford350's Avatar
what made you go with the John wood vb?
and by inconsistent, what do you mean? would it shift at different times or stick or what?
and how much did the new triple tc help out? I want one Just not willing to put it in yet. I cant afford a shop to be working on my truck for the cool add ons yet. The air force dont pay enough.
post #9 of 27 (permalink) Old 07-27-2007, 11:12 PM Thread Starter
I dont have the updated FTVB, supposedly they don't shift as hard as the one I have cause people were complaining, but they still shift too hard I hear.
Incosistent is just that, it doesn't shift the same, same road, same speed, same throttle input. Sometimes it shifts good, sometimes it slams, sometimes seems like it shifts too early.
Triple disk locks up a lot harder than the old one. Confident it's the main reason my trans is still together.
gregrob is offline
post #10 of 27 (permalink) Old 07-28-2007, 12:12 AM
Don't EFN worry about it
Aljay's Avatar
My stock 4r100 has parts from trans go in the pump and, some parts from sonnax in the Vb all so it would make nice with the PI converter. I beat on this thing alot but I do not make a crap load of power right now.I put in stage 1's and a 100 hp reflash from Jody and the damn stock e4od(200k miles) died a day later.(With help from my foot ) Oh well truck is fun to beat up on rice with .
Tuned by T Wildman
Aljay is offline
