trans vibration - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-08-2007, 12:16 AM Thread Starter
<----Colin Banks
mattymx's Avatar
trans vibration
My EX has a vibration under load and I am thinking it is the trans. Under normal driving it seems fine but there is a vibration under load and it get worse the higher the RPM's get. The power also seems to flatten out when the vibration is at its worse at 2800RPM and above. Could it be the TC or something else in the trans? I also think this could be why I am not seeing higher than 21 PSI of boost. I am going to call John Wood tomorrow but I would like to see what you all have to say. Thanks.
mattymx is offline
post #2 of 4 (permalink) Old 10-08-2007, 02:23 AM
X Racer
Racer X's Avatar
Re: trans vibration
Sure could be the TC. End play or warp from heat. Your in good hands with JW.
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
post #3 of 4 (permalink) Old 10-08-2007, 02:24 AM Thread Starter
<----Colin Banks
mattymx's Avatar
Re: trans vibration
Thanks RX... I forgot to mention that the vibration goes away as soon as I ease off the throttle.
mattymx is offline
post #4 of 4 (permalink) Old 10-09-2007, 02:10 AM Thread Starter
<----Colin Banks
mattymx's Avatar
Re: trans vibration
I called up john and he does not think it is the TC. But I forgot to tell him that the TC has unlocked under load a few times lately.... John thinks it might be driveline related.
mattymx is offline
