Goofy Transmission - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 10-02-2007, 12:37 AM Thread Starter
Bigtimearcher's Avatar
Goofy Transmission
Well, something has gotta be up with my tranny... not exactly sure what though.
When driving, on occasion, my throttle will be extremely touchy, a few times I've heard that marblely gargley tc sound (not usually, just every once in a while) and sometimes the throttle will have a laggy feel to it. Just seems like the thing is posessed basically.
A couple of mornings pulling out for work, the check engine light went on briefly, but went away.
Oh, and the trans fluid when I checked the dipstick is just a hair darker than cherry....still has red to it.
For the most part, it seems fine.... but these fits it goes into are annoying.
Anybody got an idea?
2009 Ford F250 CCSB Lariat. H&S Minimax tuner, AFE 4" dp back exhaust, AFE Stg 2 PG7, EGR Delete
Bigtimearcher is offline
post #2 of 6 (permalink) Old 10-02-2007, 02:50 PM
AllYourBaseAreBelongToUs
imelmo's Avatar
Re: Goofy Transmission
Well if you're getting an sel I would think it's something other than your trans, especially if it's intermittent like that.
Do you have access to a scanner for stored codes?
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #3 of 6 (permalink) Old 10-02-2007, 05:55 PM Thread Starter
Well, I don't know because the cel was a new thing....the other quirks were there prior to the light...which I haven't seen since.
post #4 of 6 (permalink) Old 10-04-2007, 04:23 AM
X Racer
Racer X's Avatar
You'll need to have the codes scanned. If the OD light on the shifter flashed it's powertrain related. If the dash check engine light flashed it's an engine related code.
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
post #5 of 6 (permalink) Old 10-04-2007, 10:37 PM Thread Starter
Well, the thing is..... it's been doing this touchy throttle thing before a code ever popped up. I've never had the od light blink.
I've since turned my chip down to 80 and it's been alright...... I'll look into a code check when I get a chance. Some day I should just buy AE!
post #6 of 6 (permalink) Old 10-05-2007, 06:09 PM
X Racer
Racer X's Avatar
I have seen 1 other that could only use 80 setting. It was in a 2000 also. Try calling CS over at TS or the dealer. There might be an update for the chip.
Racer X is offline
