5r100 swap?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 08-17-2012, 01:59 PM Thread Starter
ColeTrain45's Avatar
5r100 swap??
Could a 5r100 replace a 4r100???
ColeTrain45 is offline
post #2 of 21 (permalink) Old 08-17-2012, 03:02 PM
IH Diesel Power
Petro's Avatar
Re: 5r100 swap??
yes but you would need a stand alone controller to run it. Its also called a 5r110.
Current
99/05 F250 XLT Ccsb 4x4, 7.3l, ZF6
, Power Struck Tuned, Luk Clutch, RR, Comp 910s, and more sh!t.
Sold
99 F250 Lariat Ccsb 4x4, 7.3L, 4R100, The Basics
Totalled
08 F250 Lariat Ccsb 4x4, 6.4L, 5R110, SCT Livewire IDP Custom Tuned, 5" Exhaust, Custom Traction Bars.
Petro is offline
post #3 of 21 (permalink) Old 08-17-2012, 08:44 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 5r100 swap??
Sure can. Here's some things you'll need to do to make it work:
It's WAY harder to make software shift a TorqShift than a 4R100, due to the design of the two transmissions.
The 4R100 is an all non-synchronous design. This means that for each upshift all that happens is a clutch is applied. All you need to do is control the pressure to the oncoming clutch and you're all set.
The TorqShift is MUCH more complicated. The 1-2 and 5-6 shifts are the same, they are non-synchronous and all you need to do is control the pressure of the overdrive clutch. The other shifts are the problem.
The 2-3 is a swap shift. This is a special catagory of difficult shift. I believe Ford is the only trans maker in the world that still does swap shifts. Others have put swap shift transmissions in production and then replaced them within a few years. To make a swap shift the TorqShift needs to release the overdrive clutch to downshift the overdrive gearset while applying the intermediate clutch to upshift the Simpson planetary gearset. This is an upshift and a downshift occuring at the same time in the same trans. From my experience these two shifts MUST complete within 30 milliseconds of each other or it's going to feel awful. If the overdrive releases too soon the engine speed will flare. The amount of flare is dependant on how much sooner it completes. If it completes before the intermediate has enough capacity the trans goes back to first gear! Then it has to make a 1-3 shift. A few WOT 1-3 shifts means the trans comes out to replace the intermediate clutch. Been there, done that. If the overdrive releases after the intermediate comes on you end up in 4th gear (1.09:1 ratio) then downshift back to third gear (1.54:1 ratio.) Either way it's really bad.
Now if you made it though that you need to make a 3-5 shift. 4th gear is the 1.09:1 ratio that really isn't used. The 3-5 is a synchronous shift. It's timing requirements are about the same as the swap shift, but there is no downshift. To make the shift the intermediate clutch has to release while the direct clutch applies. If the intermediate releases too soon you get an engine speed flare. If the intermediate releases too late you get a tie up. A tie up is when all three pieces of the planetary gear set are held from turning. This means the output shaft of the trans STOPS. That's not a pleasant thing to have happen when you're at WOT making a 3-5 shift. You can lock the wheels on an upshift! I've done this, too. You can also break expen$ive parts doing a tie up. Been there, done that, too.
Now start thinking of the combination shifts that can happen. How about cruising at 55 MPH behind some slow poke on a two lane road? A passing zone opens and you floor it. Now you may want to go from 6th to 3rd gear. You need to release the direct clutch and apply the intermediate. That's a synchronous shift in reverse.
As you can see from just these few examples it isn't a trivial task to make one of these transmissions shift. It's what I did at Ford for quite a few years, three of them working on the TorqShift. I'd be really surprised if anyone makes a controller for the TorqShift that works really well. I think someone could make one that does some basic shifting, but getting one so that it shifts at least as well as a stock trans is going to be a HUGE task.
Mark
Mark Kovalsky is offline
post #4 of 21 (permalink) Old 08-17-2012, 08:59 PM
Administrator
Zmann's Avatar
Re: 5r100 swap??
getting to be a common question lately
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 21 (permalink) Old 08-17-2012, 10:21 PM
jdgleason's Avatar
Re: 5r100 swap??
Good info here.
'09 F350
-JD
jdgleason is offline
post #6 of 21 (permalink) Old 08-17-2012, 11:42 PM
Administrator
Zmann's Avatar
Re: 5r100 swap??
I remember in the olden days Mark used to type that whole response
then I showed Him how to paste and copy
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #7 of 21 (permalink) Old 08-18-2012, 12:23 AM Thread Starter
Re: 5r100 swap??
Mark you are the man. Where do you live I'd like to take you out for a beer or two lol no gay funny business just saying you are one smart dude.
post #8 of 21 (permalink) Old 08-18-2012, 12:28 AM
Administrator
Zmann's Avatar
Re: 5r100 swap??
Better send Him a Beer gift card ,, even I am scared now
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 21 (permalink) Old 08-18-2012, 12:28 AM
Re: 5r100 swap??
I lived in the Detroit area for my first half century. Now I live in South Florida.
Mark
post #10 of 21 (permalink) Old 08-18-2012, 02:54 PM Thread Starter
Re: 5r100 swap??
Lol I live in ortonville. Where abouts in Florida. That's where I'm from and go down twice a year to visit family.
