ZF5 differences? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 08-17-2012, 09:10 AM Thread Starter
up to no good
ontwowheels's Avatar
ZF5 differences?
I just bought a used ZF5 and t-case from an '88 7.3 truck to go into my '96. Aside from the slight ratio changes between the -47 and -42, are there any other differences I should be aware of? Will all the wiring/sensors from the older tranny work with the rest of my '96?
1996 F250 XLT, 4x4, 5 speed, LuK clutch, scsb, manual hub conversion, 265/75R16 Wrangler Territories, Tymar intake
2001 Yamaha WR250F, wayyyyy to much stuff to list. very YZ-ified
2012 Honda NC700SA, MRA windscreen
ontwowheels is offline
post #2 of 4 (permalink) Old 08-17-2012, 10:30 AM
Re: ZF5 differences?
From what I was told, The main thing is the Gear Ratios on the first few gaers are differant..
metrojd is offline
post #3 of 4 (permalink) Old 08-18-2012, 04:50 PM
There are no sensors on the ZF5. The only electrical connection to the ZF5 is the reverse light switch, and it should be the same. The -42 is rated to withstand less torque than the -47.
There is a set of position switches on the t-case, that turn on the 4x4 and Low Range lights on the dash. The connectors may be different between the two years. Just in case they're different, you should be able to surmise, either from a diagram or from simply ohming the combinations of wires with the shifter in its various positions, which wire is which and splice in the connector.
madpogue is offline
post #4 of 4 (permalink) Old 08-18-2012, 06:42 PM Thread Starter
up to no good
I'm going to re-use the t-case that's already in the truck, otherwise I'd have to get my hands on the slip yoke to go with the output shaft.
