1997 e4od issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 08-14-2012, 07:02 PM Thread Starter
OBSpstroke97's Avatar
1997 e4od issues
so heres whats going on with my truck. when my transmission is cold the transmission shifts fine with no issues at all. right when it gets to around 150* it will start slipping while going into first or reverse, also it will hang up when shifting between gears. i haven't dropped the pan yet to check for clutch material ect. the only other thing is the fluid is burt (this was newer fluid) and i threw it on a scanner and it pulled up P1728 transmission slip malfunction. thanks for any input.
1997 F-250, D60, 8in lift/38s, OUO ladder bars, BTS, Spearco 6.0 IC, SRP 1.1, Irate 468 turbo, Dyno proven tunes, P.I.S 300/200s, ARPs/910s/Smith bros push rods, A1000/sump.
[email protected] on 38s
OBSpstroke97 is offline
post #2 of 7 (permalink) Old 08-15-2012, 12:51 AM
Fixing Broken Stuff
toolmangary's Avatar
Re: 1997 e4od issues
Start saving some $$$$
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #3 of 7 (permalink) Old 08-15-2012, 02:14 AM Thread Starter
It just doesn't make sense how it will drive perfect for the first 10-15 min of driving then all of a sudden start acting up. don't get me wrong im planning on getting a bts in the future but if its something stupid wrong with it right now that can be fixed for cheap then ill do that to save time.
post #4 of 7 (permalink) Old 08-15-2012, 03:56 AM
Fixing Broken Stuff
As it heats up it probably develops a pressure leak.
2004 Jetta TDI
1956 F100
post #5 of 7 (permalink) Old 08-16-2012, 03:05 PM
Or a weak pump. As fluid heats up and thins out you loose pressure.
There is a pressure test port on the side of the trans. Any trans shop can thread one in and check it for you.
Most will do it for free.
BTW if the fluid looks burnt, but isn't that old, it's either full of clutch dust, or you have a clogged cooler and overheated it.
1997 F250 05+ Axle Swap 3.73 Home Built 4-link Front with Ballistic Parts. 2.5" Front Coils. B-code Rear. DIY Trans w/ Precision COnverter. DIY Traction Bars. TDP 6-Pos Chip BW TP38 w/ 1.00 EXH. Rosewood DIY STG1's. DIY E-Fuel w/ Dual FM100's. SD quad pod above Rearview
turboaz2 is offline
post #6 of 7 (permalink) Old 08-16-2012, 04:10 PM Thread Starter
Thanks for the reply I replaced the cooler when I did a full trans flush and replaced the TC.
The fluid is a synthetic blend if that makes a difference and has approx 30 k on it. Also I never noticed temps on my trans gauge above 150-160
post #7 of 7 (permalink) Old 08-16-2012, 06:45 PM
30k miles?
Time for new fluid.
I do a drain and fill every 15k.
Does the fluid smell burnt?
Wipe the dipstick on a clean paper towel.
If it's clutch material, the red will bleed out into the towel and the dust will stay where you wiped it.
turboaz2 is offline
