Drive does'nt always engage - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 08-11-2012, 03:39 PM Thread Starter
sweetdreamz's Avatar
2001 350 4X4 auto, 4r100, previous owner replaced the transmission with a low mileage used unit (160k).
I've searched this problem and found a few members with the similar issue, but mine is a little different. Drive gear will engage maybe half the time, does not matter if the tranny is hot or cold. Have to start in 1st then bump up to drive. Took it to a tranny shop and it worked the whole time for the test drive, until I left. Pretty much flip a coin and it might work.
For some strange reason it will always engage after i back out of my driveway (slight incline) onto the most level part of the road. If I back up all the way with my back wheels off the road, taking the truck slightly off level, it won't engage. WTF.
Fluid level is fine. One member talked about a loose center support bolt, could that cause this? Opinions would help, ready to try anything before actually replacing the tranny.
2001 F350 7.3 CCSB 4X4 - 6-position chip (Bean's) - Riff Raff 6637 intake kit - foil delete - 8" single stack - 6" lift (unknown brand) - 05 front end conv w/HID projector - 20x10 XD strike - Federal couragia 35x12.50x20
sweetdreamz is offline
post #2 of 4 (permalink) Old 08-11-2012, 06:13 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Drive does'nt always engage
I does sound like an internal leak. The feed bolts could do it, but I suspect a failing seal in the forward clutch.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #3 of 4 (permalink) Old 08-11-2012, 09:53 PM Thread Starter
So I need a rebuild? Figured their was no easy way out.
Thanks for the response.
post #4 of 4 (permalink) Old 09-13-2012, 01:48 AM Thread Starter
Wanted to try everything before taking the rebuild plunge. Just installed a new DTR sensor, now drive engages right at the begining of the "D". How do I adjust?
