gas e4od extension housing fit a 97 e4od - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 07-19-2012, 03:09 AM Thread Starter
konzkustomz's Avatar
i have a broken extension housing on my 97 7.3.. I thought i read online that a gas job housing would be the same. It just so happens i have a 95 f150 5.8L with the e40d in it. ive been searching with no luck so far to find a new one. Does anyone know if the gasser one will fit? Thanks
97 crew cab long bed 4x4, auto,165k on the truck,3"down pipe, 5" exhaust, DIY 6637 filter,6 position chip TW tunes, 6.0 inner cooler,pillar gauges,4" lift, 35x12.50" tires and soon to come a T500, stage 1's and E-fuel ,KT torque converter
konzkustomz is offline
post #2 of 3 (permalink) Old 07-19-2012, 04:44 AM
bracketracer's Avatar
Re: gas e4od extension housing fit a 97 e4od
I'm assuming that the '97 is the 4x4 in your sig and that the '95 is also a 4x4. Yes, they would be the same. Only thing you may need to do is plug the speed sensor hole if the '95 housing even has one.
Newest project: 1995 F350 CC/DRW 2WD E4OD. 3" DP, 4" Diamond Eye system. But I'm still fixin' the broken stuff......
bracketracer is offline
post #3 of 3 (permalink) Old 07-19-2012, 09:22 PM Thread Starter
yes both are 4x4... thanks, guess i have some work to do now
