Won't Engage in Drive When Hot - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-15-2012, 11:04 PM Thread Starter
The Ontaribertan.
Sluther's Avatar
Haven't posted in quite a while. I hope everyone is doing well.
I'm having a tranny issue. At first it was just an intermittant thing but now its happening all the time, so I want to take care of it. When going from Park or Reverse into Drive, the truck won't engage in gear. And for some reason it only happens when the truck is warm. If I let it sit for a few hours or overnight, it will engage fine in the morning. At first, If I just dropped it down into 1st, it would engage and then I could move it back to Drive, but now, even that doesn't work.
Took the truck to Ford and the tech said he found a sticking valve in the valve body, so they put a new valve body on and the problem is still happening. They also checked a TR sensor? (I don't know much about transmissions) and they said it seemed fine. They also said that there were no shavings in the fluid and that there were no signs of any serious problems with the transmission itself.
So, the problem is still happening and the dealership manager says the ONLY other thing it could be is the piston. Once the truck engages, it runs and shifts just fine.
I just wanted to run this by the forum before I give the go-ahead to tear it down and replace the piston. Does this sound consistent? or are there any other ideas out there?
Thanks in advance.
SOLD -- 2000 F250 7.3 RegCab 4x4
2001 F250 SCSB 4x4 Lariat 120k -- 2.5" Levelled, Duelers on 20in Fuel Octanes, K&N Intake, MBRP 4", DP Tunes, AutoMeter Ultra-Lites.
1971 Chevelle 454 SS Clone -- Father/Son restoration
Sluther is offline
post #2 of 6 (permalink) Old 07-16-2012, 12:50 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Won't Engage in Drive When Hot
Yes, that sounds reasonable.
Mark
Mark Kovalsky is offline
post #3 of 6 (permalink) Old 07-16-2012, 05:22 PM Thread Starter
The Ontaribertan.
Sluther's Avatar
Ah, thanks for the response Mark.
So what he's saying makes sense to you? He said the pistons were a fairly common problem with the 4R100s.
Anyone else ever dealt with this? I just wanna rule anything else out.
Thanks again.
Sluther is offline
post #4 of 6 (permalink) Old 07-16-2012, 09:06 PM
Yes, it's not an uncommon failure.
Mark
post #5 of 6 (permalink) Old 07-16-2012, 10:58 PM
It could also be a loose center support bolt. No need to pull trans to check pan and vb need to come down have seen this before a few times.
range91 is offline
post #6 of 6 (permalink) Old 07-17-2012, 04:25 PM Thread Starter
The Ontaribertan.
Sluther's Avatar
Alright, I'll make sure they check that too.
Thanks guys.
Hopefully this clears up, this happened when I had the 5th wheel out 2 weekends ago as I was parking it. So because it wouldn't engage in drive, it was stuck halfway onto my site, and half blocking the street in and out until morning. Needless to say, they weren't too happy with me.
Sluther is offline
