5r100 into obs? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 07-12-2012, 02:23 PM Thread Starter
5r100 into obs?
Planning out my 2nd cummins swap, fordcummins states that putting a 5r100 and its t-case is an easy swap. Has anyone done this swap? I'll be mating it to a 12 valve with their adapter. I was just wondering if the pcs controller connections take care of everything or is there going to be more sensors and connections?
fummins97 is offline
post #2 of 19 (permalink) Old 07-16-2012, 12:29 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: 5r100 into obs?
I can't help you but I'd like to know how it works out for you.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #3 of 19 (permalink) Old 07-16-2012, 01:45 PM
TBarrsTruck's Avatar
Re: 5r100 into obs?
If you were going to use a stand alone trans controller then I don't see why not. A stand alone computer will come with the nessary harness per application.
'97 4x4 ECLB: SD IC, TW 4 pos, afe, 3-4" w/areoturbine, 4 gauge, DIY stage 1s, GTP38R, cust E-fuel, E-brake, stage3 CM meth, 439hp still trying for 600. cust stereo, highamp alt, cust paint
'78 F-150 RCLB: 460 swap, 3" lift, 33's,Trussed 9" w/ chrome-moly shafts, cust stereo, locked front/rear. My first love! EFI & Turbo coming soon...
TBarrsTruck is offline
post #4 of 19 (permalink) Old 07-16-2012, 08:22 PM Thread Starter
Re: 5r100 into obs?
Finally some response lol, thanks guys, not sure if this is the route I'll take, I've just read and heard that the 5R is stronger right from the factory. I will do a build thread when the time comes. Thanks.
post #5 of 19 (permalink) Old 07-16-2012, 08:24 PM
itsdieselornothing's Avatar
Id stick with the 4r. Alot of 6.4 owners that are pushing over 800 hp are switching to a 4r. 4rs are a lot stronger when u build them and a lot cheaper.
Sent from my Autoguide iPhone app
itsdieselornothing is offline
post #6 of 19 (permalink) Old 07-16-2012, 08:25 PM
MOTO MANIAC
MOTO7.3's Avatar
Re: 5r100 into obs?
Do you already have the 5r100 is that why you are using it. If you still have the e4od why not have JW or BTS just build it for you and save the headache of trying to make the 5r100 work.
The Black Sheep.
E99 F350 CCLB
5r110 trans cooler and filter.
4''mbrp, Isspro boost, trans, EGT,
S&B CAI. NO Limit tunes
MOTO7.3 is offline
post #7 of 19 (permalink) Old 07-17-2012, 02:25 AM
Re: 5r100 into obs?
If he is swapping in favor of a cummins into an obs truck he will need a stand alone trans comp anyhow so why not use the better trans, the rest of the interfacing will be nearly the same.
post #8 of 19 (permalink) Old 07-17-2012, 02:33 AM
MOTO MANIAC
MOTO7.3's Avatar
Re: 5r100 into obs?
I think that a BTS or a JW trans is much better than a Stock 5r100 they have proven to hold more power with less money, Plus both of the builders and great with warranty's. Just my two cents.
The Black Sheep.
E99 F350 CCLB
MOTO7.3 is offline
post #9 of 19 (permalink) Old 07-17-2012, 02:42 AM
Re: 5r100 into obs?
I would agree that a good tranny with a good warrenty is always a good route
post #10 of 19 (permalink) Old 07-17-2012, 02:43 AM
Was PSD0389
Matt_P's Avatar
Re: 5r100 into obs?
I wouldnt waste my time swapping in a 5r. they do not like to work well with standalone controllers. Main reason I didnt use the 5r in my swap. You would be much happier with a PCS and 4r combo
03 F-350 CCLB King ranch undergoing a 6.0 delete
99 Fummins- SOLD
95 F250- SOLD
08 6.4- Totaled 12/19/10
Matt_P is offline
