Zf6 issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 07-05-2012, 12:51 PM Thread Starter
OBSpstroke97's Avatar
Zf6 issue
Heu guys my dad has a 2000 f250. It's got a zf6 with a south bend clutch. The truck it self has 160,000 on it and the clutch has about 60,000 on it. The other day the clutch peddal got very soft and it's pretty hard to put in gear also I can smell clutch burning . I checked the bushing under the dash it didn't seem
To have to much play in it. Any ideas on what could be wrong ? I was going to change the slave cylinder
1997 F-250, D60, 8in lift/38s, OUO ladder bars, BTS, Spearco 6.0 IC, SRP 1.1, Irate 468 turbo, Dyno proven tunes, P.I.S 300/200s, ARPs/910s/Smith bros push rods, A1000/sump.
[email protected] on 38s
OBSpstroke97 is offline
post #2 of 24 (permalink) Old 07-05-2012, 04:10 PM
Canadian Stroker
doubledoor's Avatar
Re: Zf6 issue
Get a new pre bled clutch master and slave. They are made out of plastic and don't last.
2002 XLT CC LB 6speed SRW
4"mbrp turbo back
S&B Intake
autometer NV boost,pyro,water temp and oil pressure
WW2,BRV
DP tunes - QI,60E,80E,40T,60T,100,120.
EBPV delete sensor.
blank pedestal and EBPV housing
ATS turbo housing
DI up-pipes.
2007 headlights,2008 taillights,2010 tailgate
17"Atx ledge with Dick Cepek Extreme Country
doubledoor is offline
post #3 of 24 (permalink) Old 07-05-2012, 04:35 PM Thread Starter
Re: Zf6 issue
Ten 4 , get it from ford?
post #4 of 24 (permalink) Old 07-05-2012, 04:40 PM
Strokeradict's Avatar
Re: Zf6 issue
Yea I got one last year and I think it was like $125
1996 F-250 ECLB Auto 259k miles Hpop out of an 99 7.3, 4'' stack, Guages, Custom front bumper SOLD
1999 F-350 ECLB Built Auto 465k and counting motor is bone stock for now
1994.5 F-350 CCLB 222k Stage ones, bigger clutch, motor was completely rebuilt at 202k. Big plans
Strokeradict is offline
post #5 of 24 (permalink) Old 07-06-2012, 09:22 PM
Canadian Stroker
doubledoor's Avatar
Re: Zf6 issue
I talked to my local stealership and they could only sell me either the master or the slave. Big suprise the dealer is not very helpful. So I went to my local parts store and they got me the pre bled kit. Easy to install. They both just twist and pull out.
4"mbrp turbo back
S&B Intake
WW2,BRV
EBPV delete sensor.
ATS turbo housing
DI up-pipes.
post #6 of 24 (permalink) Old 07-07-2012, 12:09 AM Thread Starter
Re: Zf6 issue
Ok I pulled out the shaft from the trans and had a buddy depress the clutch and the rod moved out fine. Would this mean it's still working correctly ??
post #7 of 24 (permalink) Old 07-07-2012, 04:09 PM
Canadian Stroker
doubledoor's Avatar
Re: Zf6 issue
Could be leaking internally. It might work fine when there is no load on it but when it has to push the pressure plate it might not be moving all the way.
4"mbrp turbo back
S&B Intake
WW2,BRV
EBPV delete sensor.
ATS turbo housing
DI up-pipes.
post #8 of 24 (permalink) Old 07-07-2012, 07:33 PM
Running at last...
powerstroke cowboy's Avatar
Re: Zf6 issue
Nope!!! If it was getting the pressure it needed it would blow the shaft and seals right out the end of the slave cylinder....
I would try a new slave cylinder.. nd if that does not work.. then your master might be bad...
97 CCLB 4x4 ZF6 [email protected]
powerstroke cowboy is offline
post #9 of 24 (permalink) Old 07-07-2012, 08:38 PM Thread Starter
Re: Zf6 issue
I just replaced master and slave , I got a pre bled one from napa. Now it won't even go into gear, it would with the old one just with a little force.
post #10 of 24 (permalink) Old 07-07-2012, 11:22 PM
Running at last...
Re: Zf6 issue
Does the pedel push easy then get hard close to the floor????
