transmission compatabilty - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 07-01-2012, 12:03 AM Thread Starter
I have an '01 F350 and my tranny went out. Things are alittle tight and I dont have the $3500 they say it will cost to fix it. A friend has a '97 he is parting out, and offered me the tranny. My question is will it fit? Thanks in advance.
Magilla is offline
post #2 of 3 (permalink) Old 07-01-2012, 02:40 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: transmission compatabilty
Yes, it will fit and it will bolt up if both are 4x4 or both 4x2 and both have the same engines. It won't work, however.
Your 4R100 has speed sensors that the PCM needs to control the transmission. The E4OD he has does not have the sensors. It would cost A LOT less to rebuild your transmission than to retrofit an E4OD with those sensors.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #3 of 3 (permalink) Old 07-01-2012, 04:15 PM Thread Starter
Thank you Mark. I appreciate the help.
Magilla is offline
