E40D won't shift past second. HELP!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 06-21-2012, 07:56 AM Thread Starter
I have a 1997 power stroke and while driving one day took off from a stop sign and wouldn't shift past second. The trans doesn't slip or shift hard and no OD light. If you floor board the throttle it will shift from first to second and when time to shift to third it hits rev limiter like the trans is in neutral. Slow down to a certain speed it shift back into second and pulls. I have read a few forums about this but just looking for easy ways to solve this problem without sending to the shop. If anyone has any input please let me know. This is my daily driver and I need her running.
Also had a used 30000 mile trans put in about 3 years ago with shift kit aftermarket valve body and sun coast torque convertor.
raceready12 is offline
post #2 of 2 (permalink) Old 06-21-2012, 03:21 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: E40D won't shift past second. HELP!!!
Does it have reverse? That will test if the direct clutch works. The direct is used in reverse, third, and fourth gears.
If reverse works it most likely is a stuck valve in the valve body, or possibly a bad shift solenoid.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
