tough going into gear while shifting - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-18-2012, 01:22 AM Thread Starter
i have a 96 f250 and recently my clutch went, well while it was getting progressivly worse i noticed it was getting harder to go into gear kind of like a pause while shifting. right berfore the clutch install it would start to engage a quarter inch off the floor so i figured the hard going into gear while shifting was because of that. well after i put in my valair clutch i still have hard shifting, clutch is good and it engages halfway up like it should. only way to describe the problem is a pause while going into gear, certainly cant shift fast. what could be the problem, bushings or something? thanks for the help
3in DP, 4 in straight, e fuel, Regulated return/ bowl delete, air dog 165, banjo bolts drilled out, ts 6 pos chip, HPX line, intercooler, EBPV delete, CCV mod, Valair Clutch
btomassacci is offline
post #2 of 7 (permalink) Old 06-19-2012, 11:06 AM
Fixing Broken Stuff
toolmangary's Avatar
Re: tough going into gear while shifting
Hydraulic clutch master or slave cylinder??
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #3 of 7 (permalink) Old 06-19-2012, 11:45 AM Thread Starter
I put a new master cylinder in with the new clutch
post #4 of 7 (permalink) Old 06-19-2012, 12:00 PM
Fixing Broken Stuff
What about the slave cylinder? also the older trucks use to break the fire wall, Ford had two different repair kit to fix the problem.
2004 Jetta TDI
1956 F100
post #5 of 7 (permalink) Old 06-20-2012, 03:24 PM Thread Starter
Yes I got the prebled master and slave. I have a feeling my syncros may be my problem. It shifted decent before the clutch got bad. I babied it I noticed it got worse but I figured it was just cuz it was so bad. Well now my clutch is good and still hard shifting. I put the permanent heim joint in so its not that.
post #6 of 7 (permalink) Old 06-20-2012, 04:35 PM
IHPowerstroke7.3's Avatar
Do you mostly notice this only going into 1st and reverse? It could be that the pilot bearing in the flywheel is seized, or seizing, causing the input shaft to spin at engine rpm even when the clutch is disengaged (pedal to floor). Some big trucks actually use a system kind of like a brake that slows the input shaft to help shifting.
IHPowerstroke7.3 is offline
post #7 of 7 (permalink) Old 06-21-2012, 02:37 AM Thread Starter
No its the same in every gear. Reverse is one of the easiest. While shifting it is like I put it in neutral for a second then put it in gear, except I'm trying to shift form gear to gear in one motion. Like a pause between
